Results 1 to 10 of 17
Thread: interacting with excel
    2009-09
    32
    Default interacting with excel
    Using visual lisp how can we preform following operations
    > adding row/column
    > merging/unmerging cells
    > deleting row/column
    I have searched excel object model & internet but cannot find some helpful material
    any code snipped/or useful internet link will be appreciated.
    thanks.
    2007-08
    201
    Default Re: interacting with excel
    You can have a look to Terry Miller's GetExcell.lsp to see how to activate a sheet in a file, then use (vlax-dump-object ...) to see properties and methods available for rows, columns, cells ...
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Quote Originally Posted by mdsalman2003 View Post
    > adding row/column
    > deleting row/column
    thanks.
    For example delete column:
    ;;;================== delete column ====================
    (defun C:DCOL (/ Col Cols ColNum ExcelApp FilePath Sht ShtName Wbk)
    (vl-load-com)
    (setq FilePath (getfiled "Select Excel file :"
          (getvar "dwgprefix")
          "xls"
          16
      (setq ShtName (getstring "\nEnter sheet name : "))
      (setq ColNum (getint "\nEnter column number to delete : "))
      (setq ExcelApp (vlax-get-or-create-object "Excel.Application"))
      (vla-put-visible ExcelApp :vlax-true)
      (vlax-put-property ExcelApp "DisplayAlerts" :vlax-false)
      (setq Wbk (vl-catch-all-apply
           'vla-open
           (list (vlax-get-property ExcelApp "WorkBooks") FilePath)
      (setq Sht (vl-catch-all-apply
           'vlax-get-property
           (list (vlax-get-property Wbk "Sheets")
          "Item"
          ShtName
      (vlax-invoke-method Sht "Activate")
      (setq Cols (vlax-get-property Sht "Columns")
      (setq Col (vlax-variant-value
           (vlax-get-property Cols "Item" ColNum))
      (vlax-invoke-method Col "Delete")
      (vlax-put-property ExcelApp "DisplayAlerts" :vlax-true)
      (vl-catch-all-apply
        'vlax-invoke-method
        (list Wbk "Save")
      (vl-catch-all-apply
        'vlax-invoke-method
        (list Wbk "Close")
      (vl-catch-all-apply
        'vlax-invoke-method
        (list ExcelApp "Quit")
      (mapcar
        (function
          (lambda (x)
     (vl-catch-all-apply
       (function (lambda ()
            (progn
       (if (not (vlax-object-released-p x))
         (progn
           (vlax-release-object x)
           (setq x nil)
        (list Col Cols Sht Wbk ExcelApp)
      (gc)
      (gc)
      (princ)
    Or add row
    ;;;================== add row ====================
    (defun C:AROW (/ Col Cols RowNum ExcelApp FilePath Sht ShtName Wbk)
    (vl-load-com)
    			   "xls"
    			   16
      (setq RowNum (getint "\nEnter a row number to insert one row after: "))
    	      'vla-open
    	      'vlax-get-property
    		    "Item"
    		    ShtName
      (setq Rows (vlax-get-property Sht "Rows")
      (setq Row (vlax-variant-value
    	      (vlax-get-property Rows "Item" RowNum))
      (vl-catch-all-apply
        'vlax-invoke-method
        (list Row "Insert")
      (vl-catch-all-apply
        'vlax-invoke-method
        (list Wbk "Save")
      (vl-catch-all-apply
        'vlax-invoke-method
        (list Wbk "Close")
      (vl-catch-all-apply
        'vlax-invoke-method
      (mapcar
        (function
          (lambda (x)
    	(vl-catch-all-apply
    		      (progn
    			  (progn
    			    (setq x nil)
        (list Row Rows Sht Wbk ExcelApp)
      (gc)
      (gc)
      (princ)
    See also Merge/Unmerge methods for the Range object
    ~'J'~
    100 Club jgardner.79905's Avatar
    2004-12
    153
    J
    Do you know how to "add" or "rename" a tab within the Excel file?
    Jason
    2009-11
    5,714
    Quote Originally Posted by jgardner.79905 View Post
    Under the Worksheets Object, look for the Add method, and under the Worksheet object look into the Name property.
    Computer Specs:
    2005-05
    Pietari, Venäjä
    1,269
    [quote=jgardner.79905;1107927]J
    Jason[/quote
    Change to your suit:
    (vl-load-com)
    ;;local defuns
    (defun ren_excel_tab (FilePath shtName newName / ExcelApp  Sht  Wbk)
    (vlax-put-property ExcelApp 'DisplayAlerts :vlax-false)
         'vla-open
    ;;;(setq Sht (vl-catch-all-apply
    ;;;     'vlax-get-property
    ;;;     (list (vlax-get-property Wbk "Sheets")
    ;;;    "Item"
    ;;;    shtName
      (vlax-for Sht (vlax-get-property Wbk "Sheets")
        (if (eq(vlax-get-property Sht "Name") shtName)
          (progn
      (vlax-put-property Sht 'Name newName)
    (vlax-put-property ExcelApp 'DisplayAlerts :vlax-true)
    (vl-catch-all-apply
      'vlax-invoke-method
      (list Wbk "Close" :vlax-true)
    (vl-catch-all-apply
      'vlax-invoke-method
    (mapcar
      (function
        (lambda (x)
          (vl-catch-all-apply
          (progn
       (progn
         (setq x nil)
      (list  Sht Wbk ExcelApp)
      (gc)
      (gc)
      (gc)
      (princ)
    (defun add_excel_tab (FilePath shtName  / ExcelApp  Sht  Shts Wbk)
         'vla-open
      (setq Shts (vlax-get-property Wbk "Sheets"))
      (vlax-invoke-method Shts 'Add)
         'vlax-get-property
        "Item"
        (vlax-get-property Shts "Count")
      (vlax-put-property Sht 'Name shtName)
    (vl-catch-all-apply
      'vlax-invoke-method
    (vl-catch-all-apply
      'vlax-invoke-method
    (mapcar
      (function
        (lambda (x)
          (vl-catch-all-apply
          (progn
       (progn
         (setq x nil)
      (list  Sht Shts Wbk ExcelApp)
      (gc)
      (gc)
      (gc)
      (princ)
    ;; main program
    (defun C:Xman (/ fname newname oldname rename_excel_tab oldName)
     (setq fname (getfiled "Select Excel File:" (getvar "dwgprefix") "XLS" 8)
           oldName (getstring T "\nEnter an old tab name:"))
           newName (getstring T "\nEnter a newtab name:"))
      ;;Rename Tab:
    ;;;(ren_excel_tab fname oldName newName)
      ;;;add tab:
      (add_excel_tab fname newName)
      (princ)
    (prompt
      "\n\t\t>>>\tType Xman  to execute\t<<<")
    (prin1)
    2009-11
    5,714
    :: OFF TOPIC ::
    Fixo,
    How does one prevent Outlook from displaying an alert, when accessing the Recipients collection for a new Mail Item object?
    I saw your usage of (vlax-put-property ExcelApp 'DisplayAlerts :vlax-false) and had hoped that would work, with my OutlookApp object, but sadly this returned an error:
    ; error: ActiveX Server returned the error: unknown name: DISPLAYALERTS
    _$
    Admittedly, I did not verify the property is available to the OutlookApp object prior to testing (for expediency).
    Any suggestion would be greatly appreciated!
    Computer Specs:
    2005-05
    Pietari, Venäjä
    1,269
    Quote Originally Posted by RenderMan View Post
    :: OFF TOPIC ::
    Fixo,
    _$
    I have not have an expeience with outlook sorry
    take look ath this page
    it may help
    http://www.rondebruin.nl/mail/prevent.htm
    2009-11
    5,714
    Quote Originally Posted by fixo View Post
    it may help
    My office is using Office 2003 right now, so there's no easy solution. We're getting new PC's in a few weeks, and they will come loaded with Office 2007 (or newer?) I believe. I'll take another crack at it then.
    Thanks for the link, Fixo!
    Computer Specs:
    2005-05
    Pietari, Venäjä
    1,269
    No problem,
    Just an idea:
    You might want to search for some info on this site:
    http://www.vbaexpress.com/forum/forumdisplay.php?f=18
    than convert it from VBA on Lisp
  1. Replies: 5
    Last Post: 2013-10-16, 05:39 PM
  2. Interacting with Revit through a UserForm
    By dangtrang37325793 in forum Revit - API
    Last Post: 2013-10-03, 08:10 AM
  3. Replies: 1
    Last Post: 2012-08-08, 05:50 PM
  4. Replies: 1
    Last Post: 2009-04-29, 11:03 AM
  5. in-place truss interacting with stick symbols
    By ck.107547 in forum Revit Structure - General
    Last Post: 2006-07-06, 12:02 PM
