Results 1 to 8 of 8
Thread: Dimension Text Line Weight
    2004-07
    19
    Default Dimension Text Line Weight
    Does anyone know how to adjust the line weight of the text in a dimension? I have recently changed the font within my dimensions and the text is now coming out really light at about a 1 or so. Also I have changed the font within my schedules from arial to city blueprint and am having the same problem with line weights there. Please advise...
    Thank you in advance,
    April
    2003-05
    5,153
    Default Re: Dimension Text Line Weight
    1. Settings . Annotations > Dimensions > Linear > Line Wight.
    2. Select Text properties > lineweight. ( or bold maybe ? )
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2004-07
    19
    Beegee,
    Thanks for the response. I have done what you suggested in regards to the dimension line weights and that setting only changes the dimension line line weight not the line weight of the actual numbers- they always stay the same. In regards to your second suggestion, which text properties are you speaking about? The schedule view properties do not have it listed nor does the object styles or line styles...
    2003-05
    5,153
    When you have the text element properties box , click edit and that will open the type properties, where you will see line weight.
    In schedules, select the Appearance tab, and then you can change the header and body text , text size, bold , italic etc.
    HTH
    Bruce Gow.
    Architect.
    Revitalize. Blog
    I could stop if I wanted to David Conant's Avatar
    2003-05
    Milton MA
    286
    Text in Revit uses TrueType fonts. As such it does not have a line weight. To get bolder text, go to the dimension's type properties, and either set your text to Bold, or select a different font.
    David Conant
    Autodesk Revit
    2003-05
    5,153
    And so, ... the line weight control in the properties dialogue box controls .... the "invisible" text selection box only ??
    Bruce Gow.
    Architect.
    Revitalize. Blog
    Revit Founder LRaiz's Avatar
    2003-07
    Newton, MA
    714
    It controls weight of leader lines.
    Leonid Raiz
    2003-05
    5,153
    Of course ! ( I knew that )
    Shows you how often I need to change the lineweight of my leaders.
    Bruce Gow.
    Architect.
    Revitalize. Blog
  1. 2013: Associate Line Weight and Text Size in viewport(s)
    By Darren Allen in forum AutoCAD Civil 3D - General
    Last Post: 2014-10-21, 06:59 PM
  2. 2012: Dimension Text has Perpendicular Line at end of text only when printed.
    By ddraynor in forum AutoCAD Annotation
    Last Post: 2013-01-10, 04:27 PM
  3. Replies: 0
    Last Post: 2008-12-11, 07:27 AM
  4. Text and Line weight problem
    By jcdecastro in forum Revit Architecture - General
    Last Post: 2006-05-16, 07:04 PM
  5. Dimension text line weight
    By renfun1 in forum Revit Architecture - General
    Last Post: 2006-05-01, 10:47 PM
