Results 1 to 10 of 10
Thread: How to Make a Black and White rendering
    2009-03
    146
    Cool How to Make a Black and White rendering
    my manager want a black and white building rendering from revit, a cool one.
    but i only know render to color one and change to back and white in PS, which is not cool at all.
    does anyone has some tricks?
    thanks
    2009-02
    Des Moines, IA
    43
    Default Re: How to Make a Black and White rendering
    Short of changing ALL of your material settings to not have color (not worth the time) I can't really think of any way to generate a black and white rendering.
    EDIT: I suppose you could also use the settings under the Adjust Exposure button on the Rendering Dialog box once the rendering is completed. Photoshop is going to give you far more control over your image quality and contrast than those tools though.
    Honestly, I'd say your best bet is probaly to take it into photoshop and edit it using the black and white conversion tools available to you there. If its a dramatic look that you're after, try messing with the Levels or Curves adjustments to give it higher contrast.
    AUGI Addict jeffh's Avatar
    2002-09
    Manchester, NH
    1,087
    You might be able to create a new phase in the project and create a view looking at that pahse and then all of the model will move into and "existing" state and will be assigned the material you define in the phase setting dialog (graphic overrides) dialog.
    the attached example images are of the exact same wall in 2 views set to different phases. The Revit phasing functionality has done all of the material "remapping" for me.
    2003-04
    Chino, CA
    4,756
    Yep, phasing with Phase over-rides is totally the way to go!
    2015-10
    Wellington , NZ
    565
    Quote Originally Posted by yanyan77 View Post
    my manager want a back and white building rendering from revit, a cool one.
    thanks
    Is this not good enough ?
    Straight out of Revit, using only the Exposure controls, no post production just save and go.
    regards
    trombe
    2007-02
    Alexandra, New Zealand
    237
    Quote Originally Posted by Scott Davis View Post
    Hi Scott. That is cool. I can now get everything Rendering White. How can I get the glass rendering as glass.
    Cheers
    Phillip
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by jeffh View Post
    But there's no material, texture, surface, etc. on that 2nd version.
    2002-09
    Manchester, NH
    1,087
    Quote Originally Posted by patricks View Post
    I was under the impression from the original post, a "chipboard" type generic model was what the desired effect was. If you just want a b/w version of the color rendering, then use the exposure controls and set the saturation level to 0. This will give you a grayscale image. Or you can take the color rendering and manipulate in a photo editor.
    2009-03
    146
    thanks. i will try this. because we still want to keep the material and textures
    2001-12
    1,714
    thanks
    What is wrong with changing is PS? A rendering in Revit is functionally static anyway, why worry about 10 minutes worth of post processing? And the rendering likely needs to go on a board anyway, which means probably post processing for contrast correction relative to the print device.
    One thought, render in color in Revit, then have the manager look at the view screen of a digital camera pointed at the monitor. Give em black & white, sepia, vignette effects, whatever the camera is capable of.
    Gordon
  1. PDF black and white
    By jenniferchavez in forum AutoCAD Plotting
    Last Post: 2012-01-27, 01:41 PM
  2. Black and White Rendering
    By jspartz in forum Revit Architecture - Tips & Tricks
    Last Post: 2010-10-18, 11:44 AM
  3. dwg to pdf plot: how to make black & white?
    By archbaech in forum ACA General
    Last Post: 2009-09-30, 03:13 PM
  4. black & white
    By rpassarella in forum AutoCAD General
    Last Post: 2007-06-19, 05:43 PM
  5. black and white
    By nanoaguilar2000 in forum AutoCAD Plotting
    Last Post: 2005-04-22, 07:08 PM
