Two Images
1-how do I get rid of the little tag between the stairs that doesn't have the riser rake cut out of it? I can drag that last riser line across and it cuts it out, but doesn't cut our the portion below the tread under that riser.
How do you get monolithic stairs to connect to the floor? I couldn't get a bottom landing to work. Just the mid landing. I'd like the underside of the stringer to run through and "fillet" (in AutocAD terms, if you were drawing a section - I am beyond thinking of Revit in autocad terms, but I couldn't think of how to describe this problem) with the stair.
