Anyone have a problem that Layer Properties Manager crashes or errors out if you leave it open do some cadding and then return to it to access it?
I'm using AutoCAD MEP 2010 Service pack/patch/what ever it's called now - 1.
George V. Fournier Jr., CTS
Drafting Supervisor - AutoCAD 2013 (Win 7 64-Bit intel i5-2540M CPU 8GB RAM)
2006 AUGI DAWG (7th) - Paramus NJ AUGI Camp
Volunteer Firefighter since 1985 & Bagpiper Wanna-be
With the freedom of expression comes great responsibility
I'm still using the traditional layer dialog. There's a system variable for that... LayerDlgMode?
R. Robert Bell
Design Technology Manager
S P A R L I N G
Opinions expressed are mine alone and do not reflect the views of Sparling.
I posted this message a few weeks ago,
http://www.forums.augi.com/showthread.php?t=109786
is this similar to the error you are receiving
the only constant I have found is that it will error after i minimise a window (usually internet explorer) that was over the Layer Properties manager. after that the image of the internet explorer is visible where the layer list should be.
The layer drop down list and all commands (make layer current, match properties, etc.) still work, I just cannot work through the manager (change layer properties, utilise layer filters, etc.)
