Results 1 to 8 of 8
Thread: Exporting overridden dimensions to autocad
    100 Club Priit.L's Avatar
    2003-02
    Tallinn,Estonia
    193
    Question Exporting overridden dimensions to autocad
    In Revit I can replace dimension value with text.
    When I export it to Autocad, it is changed back to value.
    Is it just me ?
    Priit
    Structural Engineer
    2008-04
    215
    Default Re: Exporting overridden dimensions to autocad
    Quote Originally Posted by Priit.L View Post
    Is it just me ?
    No it is not just you. But for me it is only when I convertpstyles that the dimension overrides lose their value. If I don't convertpstyles the dim stay as they should.
    Hope this helps
    2003-02
    Tallinn,Estonia
    193
    I have never used "convertpstyles".
    I have those values already replaced with defaults when opening exported drawing.
    Priit
    Structural Engineer
    2006-01
    Milwaukee, Wisconsin
    383
    We're having the same issue. I'm wondering if it is related to the know issue that when you add a dimension reference to an overridden dimension it loses the override and reverts to the actual dimension.
    Have you issued this through the subscription website as a bug?
    __________________
    Rick McElvain
    Arnold and O'Sheridan
    2003-02
    Tallinn,Estonia
    193
    It seems that the problem is with files that are converted from previous versions of revit.
    New project , started from revit 2010 template, are acting correctly.
    Can anybody verify that?
    I am waiting for an answer from Autodesk, it has been over a week now.
    Priit
    Structural Engineer
    All AUGI, all the time dpasa's Avatar
    2004-08
    Greece
    636
    Thumbs down Re: Exporting overridden dimensions to autocad
    This is ridiculous... Do we have to look for this too?
    2008-03
    Hi,
    We have Revit 2010 and I noticed that the dimension text override depends simply on dwg export settings. If you open 'Export CAD formats' window and see the tab 'DWG properties' you can find the setting 'Layers and properties' as first.
    When using option 'Category properties BYLAYER, overrides BYENTITY' dimension overrides remain also in dwg as they are in Revit, but if selecting other two options dimension text overrides changes back to values in exported dwg.
    2003-02
    Tallinn,Estonia
    193
    Quote Originally Posted by sanna.partanen View Post
    Hi,
    Nice work.
    Have you also reported this to Autodesk?
    Priit
    Structural Engineer
  1. Dimensions changing when exporting to Autocad
    By titanfirm in forum Revit Structure - General
    Last Post: 2009-09-08, 04:50 PM
  2. Exporting Dimensions to AutoCAD - Exploded?
    By Thomas Maleski in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-04-11, 01:02 AM
  3. Dimensions not exporting
    By Davied2 in forum Revit Architecture - General
    Last Post: 2008-02-15, 08:44 AM
