Thread: Making Concrete monolithic:
    2009-02
    Toronto, ON
    173
    Default Making Concrete monolithic:
    For anyone out there:
    I am new to Revit Structure, and I am starting to experiment with it. I was wondering if anyone has any good tips for making concrete walls, beams, slabs, columns etc, completly monolithic without having to go in and join all of the elements together by picking them using the join tool.
    Any help greatly appriciated!
    ___
    JJ
    2003-11
    Sutton Surrey United Kingdom
    238
    Default Re: Making Concrete monolithic:
    Take a look at my posting at http://cadalot-revitlearningcurve.bl...rete-beam.html when I fit one beam inside the other they automatically merge because they are made of the same material.
    When I model Ground beams and piles I make the materials different so that the 50mm kicker of the pile going into the beam shows up.
    So check that materials for all your elements are the same.
    We have also found that you have to miter the corners for hidden lines to work properly
    HTH
  1. Editing concrete parameters to show concrete type
    By Buzter in forum Revit Structure - General
    Last Post: 2010-02-08, 04:08 PM
  2. Replies: 3
    Last Post: 2008-09-03, 01:12 AM
  3. Concrete slab won't cut Concrete Foundation Wall
    By BigBadBIM in forum Revit Architecture - General
    Last Post: 2008-08-15, 03:18 PM
  4. Monolithic Concrete Stairs
    By Arnel Aguel in forum Revit Architecture - General
    Last Post: 2003-10-30, 08:43 PM
