Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: R-MEP 2010 install broke ABS07
    I could stop if I wanted to ameador's Avatar
    2006-02
    414
    Default R-MEP 2010 install broke ABS07
    Don't know quite where to post this.
    Mods..please move it as you see fit.
    We are running R14 (I know), ABS 2007, and have just installed R-MEP 2010 on a few computers.
    When I installed (a network license 32-bit system version) R-MEP 2010, the i-dropper function of the Content Browser in ABS 07 is now broken. It does not give any error codes, so I can't post anything on it. It shows up, it looks like it will i-drop in and then it just disappears.
    Any ideas??
    My gues is a dll, arx or dbx file has been overwritten??
    CAD user since '95, CAD Mgr since '07, Mech Eng
    R10, R14, 2000i, 2002, 2004, ABS 2007, AMEP 2009, 2011 & 2012, RMEP 2011 & 2012
    Author of: http://ab-nerd-disc.blogspot.com/
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    Default Re: R-MEP 2010 install broke ABS07
    I can fix it for you.
    You need to use RegEdit, locate:
    HKEY_CLASSES_ROOT\CLSID\{34d71ea5-7e74-4bb5-84da-fd59b4f63c52}\InProcServer32
    Edit the Default key to be:
    C:\Program Files\Common Files\Autodesk Shared\AcInetEngineps16.dll
    Unhappily, I think you will find that when you run Revit, that key value may switch back to AcInetEngineps18.dll rather than stay at 16. So you may need to keep a registry file handy to quickly merge the fix.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2001-04
    127
    Robert
    I've got this same thing happening to my Architecture 2009...one day the I-drop just stopped working. Ameador's description is exact what my machine is doing. I now have to use Design Content to get the objects.
    I must have done something but I can't think what it may have been. We haven't installed 2010 because of the file format conflict. And 2009 was working fine until a few weeks ago.
    Would this fix work for me? I'd try it but I'm not a techie and don't like messing with the registry unless I know exactly what I am doing.
    Thanks, Tom
    2006-02
    414
    Thank you Robert!
    We'll take a look.
    Do I just need to find a computer that has the "16" file on it and copy that across, I assume?
    2006-02
    414
    Robert,
    I had found that these files were also "altered" during the R-MEP 2010 installation. Do I need to worry about any of them as well?
    P's computer did not get R-MEP installed on it.
    R's computer had R-MEP 2010 installed on 10-26-09 around 4:00pm.
    If I search through here to see what has changed between P's and R's under the
    C:\Program Files\Common Files\Autodesk Shared these files changed
    	AcAxDb17enures.dll		P: 03-05-06	R: (has 18 instead of 17): 02-09-09
    	AcAuthEntities17enures.dll  P: 03-05-06	R: (has 18 instead of 17): 02-09-09
    	acadauto.chm			P: 02-14-06	R: 02-09-09
    	LiveUpdate16.dll		P: 03-05-06	R: 02-09-09
    	WSCommCntr1.exe		P: 03-05-06	R: 02-09-09
    	WebServices1.dll		P: 03-05-06	R: 02-09-09
    	AcInetEngineps16.dll	P: 08-12-06	R (has 18 instead of 16): 02-09-09
    	AcInetEngine16.dll		P: 08-12-06	R (has 18 instead of 16): 02-09-09
    	AcSignCore16.dll		P: 08-12-06	R: 02-09-09
          C:\Program Files\Common Files\Autodesk Shared\Service folder these files changed
    	AdskNetSrv.exe		P: 08-12-06     R: 06-05-08
    	AdskScSrv.exe		        P: 05-31-06     R: 09-05-07
    I did a search on R's computer for files that were changed since 10-23-09, these were the only files that came up.
    IEExecRemote.dll
    System.EnterpriseServices.dll
    System.EnterpriseServices.Wrapper.dll
    2006-02
    414
    It WORKED!!!!
    Awesome, thank you very much Robert!
    My IT guy knew what you were talking about on editing it.
    It fixed 4 of our computers.
    Interestingly enough, so far the fix is holding. We went into ABS did some stuff, closed out, went into R-MEP threw in some duct, closed out, and went back to ABS and it was still working. Went into the regkey and double checked and it was holding.
    Again, many many thanks!
    Here's a Dr Pepper for your help! -- I don't do beer
    2001-08
    Dallas TX USA
    5,825
    Quote Originally Posted by tsigler View Post
    Tom,
    Installing DWG TrueView 2010, Design Review 2010, (guessing, due to its intergration with TV), or installing Revit 2010 will cause this issue.
    I can post a TXT file that is a REG file if you want to use that to merge rather than manually editing the registry.
    R. Robert Bell
    S P A R L I N G
    2001-08
    Dallas TX USA
    5,825
    Quote Originally Posted by ameador View Post
    I don't think you will have any trouble. I've been running side-by-side installs of 2008 and 2010 for over 6 months and the iDropper issue is the only conflict I've noticed.
    R. Robert Bell
    S P A R L I N G
    2001-08
    Dallas TX USA
    5,825
    It WORKED!!!!
    I'm glad I could help, and that you were smart enough to ask!
    R. Robert Bell
    S P A R L I N G
    2006-02
    414
    No kidding?
    DWG TrueView 2010, Design Review 2010 ruins this key as well as R-MEP 2010?
    Does Autodesk know about this?
    I think that R-Arch 2010 is doing the same thing to ADT07.
  1. AutoCAD 2010 Re-install Help
    By jomzcruz in forum AutoCAD General
    Last Post: 2011-08-21, 08:49 PM
  2. 2011: ACA 2010 - Install express tools after install
    By shane.249457 in forum ACA General
    Last Post: 2010-07-14, 03:15 PM
  3. ABS07 Duct Not working Correctly
    By ameador in forum AMEP General
    Last Post: 2009-07-10, 03:07 PM
  4. Can I not install 2010 32 bit on a 64 bit OS?
    Last Post: 2009-05-28, 03:07 PM
  5. revit 2010 install
    By btrusty in forum Revit Architecture - General
    Last Post: 2009-04-27, 07:47 PM
