Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: R-MEP 2010 install broke ABS07
  1. #11
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,829
    Default Re: R-MEP 2010 install broke ABS07
    Quote Originally Posted by ameador View Post
    No kidding?
    DWG TrueView 2010, Design Review 2010 ruins this key as well as R-MEP 2010?
    Does Autodesk know about this?
    Yes, I'm the one that exposed the issue to them.
    I think that R-Arch 2010 is doing the same thing to ADT07.
    Yes, I mentioned earlier in this thread that Revit 2010 will affect AutoCAD 2007-2009.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
  2. #12
    I could stop if I wanted to ameador's Avatar
    2006-02
    414
    Thumbs up Re: R-MEP 2010 install broke ABS07
    That's just some crazy stuff.
    I really appreciate the help Robert!
    You made my day
    I'd rather post q's than bang my head against a wall and look stupid.
    I spoke with my reseller and they had not heard of this issue.
    They know now!
    CAD user since '95, CAD Mgr since '07, Mech Eng
    R10, R14, 2000i, 2002, 2004, ABS 2007, AMEP 2009, 2011 & 2012, RMEP 2011 & 2012
    Author of: http://ab-nerd-disc.blogspot.com/
  3. #13
    2001-04
    127
    Thanks Robert, but...
    I made the change in the registry, rebooted, opened ACA 2009 and tried to drop something onto a palette. No dice, still acting the same as it was. Any other ideas?
    BTW, should I return to the registry and change back?
    Thanks, Tom
  4. #14
    2001-08
    Dallas TX USA
    5,829
    Quote Originally Posted by tsigler View Post
    Sorry for the delay in getting back to this; I was speaking at a 2-day indistry event.
    There was no need to reboot. Just merge the REG file before running AutoCAD.
    Try merging and immediately running AutoCAD. If that still does not work, please export that CLSID and post the resulting file as a TXT. Unhappily for you I skipped the 2009 release but I don't believe the DLL filename changed between 2008 and 2009. You could browse to the specified folder and look at what DLLs are located there.
    R. Robert Bell
    S P A R L I N G
  5. #15
    2006-12
    9
    Thanks, Tom
    I have not tried the registry trick, but going into add/remove programs and running a repair install will also fix this issue, it may take longer though. Give that a try
  6. #16
    2001-08
    Dallas TX USA
    5,829
    Quote Originally Posted by chris410fortin View Post
    Repair does not correct the issue.
    R. Robert Bell
    S P A R L I N G
  7. #17
    2001-04
    127
    Robert
    Shortly after my last post I lost all the panels and tabs for my Ribbon. Start-up just gave me a blank ribbon with a message about no panels or tabs available. Nothing I did would bring them back so I reloaded ACA 2009 from the control panel. I still had a blank ribbon but at least when I went to "customize" I had content in the "Panel" and "Tabs" sections so I could rebuild the Ribbon.
    Still can't use I-drop though so it must be something in the registry. Unfortunately I didn't do an uninstall before I did the reload so I never cleared the registry. At this point I'm going to have to wait until we get less busy before I can play with it again.
    Thanks for all your help.
    Tom
  8. #18
    2001-08
    Dallas TX USA
    5,829
    That is a separate issue. I have found that if you open the CUI editor and set the workspace as current within the editor the Ribbon comes back. (As long as the workspace still has Ribbon elements assigned to it.)
    R. Robert Bell
    S P A R L I N G
  9. #19
    2001-04
    127
    That's what we had been doing on a couple other installations but mine lost everything. ACA seems to be getting quirkier every new iversion.
    Thanks for all you tips, Tom
  10. #20
    2010-01
    Westerly, RI
    Question Re: R-MEP 2010 install broke ABS07
    Quote Originally Posted by RobertB View Post
    I can fix it for you.
    You need to use RegEdit, locate:
    HKEY_CLASSES_ROOT\CLSID\{34d71ea5-7e74-4bb5-84da-fd59b4f63c52}\InProcServer32
    Edit the Default key to be:
    C:\Program Files\Common Files\Autodesk Shared\AcInetEngineps16.dll
    Unhappily, I think you will find that when you run Revit, that key value may switch back to AcInetEngineps18.dll rather than stay at 16. So you may need to keep a registry file handy to quickly merge the fix.
    Robert,
    I have this problem too in AutoCAD Architecture 2008 after architect installed DWG TrueVIew2010 on my machine.
    Would your fix work for me?
    I do not have HKEY_CLASSES_ROOT\CLSID\{34d71ea5-7e74-4bb5-84da-fd59b4f63c52}\InProcServer32 in my registry editor.
    Should I look for different key?
    I would appreciate help very much, since dragging objects through tool palletes is not an option for us.
    Lesya
  1. AutoCAD 2010 Re-install Help
    By jomzcruz in forum AutoCAD General
    Last Post: 2011-08-21, 08:49 PM
  2. 2011: ACA 2010 - Install express tools after install
    By shane.249457 in forum ACA General
    Last Post: 2010-07-14, 03:15 PM
  3. ABS07 Duct Not working Correctly
    By ameador in forum AMEP General
    Last Post: 2009-07-10, 03:07 PM
  4. Can I not install 2010 32 bit on a 64 bit OS?
    Last Post: 2009-05-28, 03:07 PM
  5. revit 2010 install
    By btrusty in forum Revit Architecture - General
    Last Post: 2009-04-27, 07:47 PM
