Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: R-MEP 2010 install broke ABS07
  1. #21
    2000-01
    Seattle WA USA
    5,859
    Default Re: R-MEP 2010 install broke ABS07
    Quote Originally Posted by ltoftul View Post
    I have this problem too in AutoCAD Architecture 2008 after architect installed DWG TrueVIew2010 on my machine.
    Would your fix work for me?
    I do not have HKEY_CLASSES_ROOT\CLSID\{34d71ea5-7e74-4bb5-84da-fd59b4f63c52}\InProcServer32 in my registry editor.
    Should I look for different key?
    I would appreciate help very much, since dragging objects through tool palletes is not an option for us.
    Lesya, the fix ought to work for you too. Search for AcInetEngineps18.dll as data only in the registry. BACK UP THE REG BEFORE EDITING!
    As long as the data found is in the classes root and has the same key, you should be able to edit it to the 16 version. Again, backup the registry before editing!
    R. Robert Bell
    Design Technology Manager
    Stantec
  2. #22
    2005-08
    Dallas TX
    14
    will it be the same for AutoCAD MEP 2010?
  3. #23
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by aubry27 View Post
    Yes, it is.
    R. Robert Bell
    Stantec
  4. #24
    2012-01
    Harford Co, MD
    16
    Good day all. I wonder if the issue I have been having is similar to this one?
    I've been trying to install Plant3D on my machine at home & it gets to the end & all items are RED X. Did not install. My error code is 1603 & then it has also been 0
    Please help. I have been in several posts at Autodesk but nothing has worked yet.
    The next thing I was going to try is to change the User Account Control to "never notify"
    Thanks for any advise or help on the issue.
    Mark
  1. AutoCAD 2010 Re-install Help
    By emanski in forum AutoCAD General
    Last Post: 2011-08-21, 08:49 PM
  2. 2011: ACA 2010 - Install express tools after install
    By shane.249457 in forum ACA General
    Last Post: 2010-07-14, 03:15 PM
  3. ABS07 Duct Not working Correctly
    By ameador in forum AMEP General
    Last Post: 2009-07-10, 03:07 PM
  4. Can I not install 2010 32 bit on a 64 bit OS?
    Last Post: 2009-05-28, 03:07 PM
  5. revit 2010 install
    By btrusty in forum Revit Architecture - General
    Last Post: 2009-04-27, 07:47 PM
