Results 1 to 7 of 7
Thread: Distributed Bucket Rendering
    2009-10
    3
    Default Distributed Bucket Rendering
    I am running 3DS MAX Design 2010 64 bit on a Core 2 Quad Q9300 @ 2.5GHz with 16 GB of Ram with a Nvidia Quadro FX 1700 video card. I have set up a distributed bucket rendering farm for a large still image. It requires to be printed 24 x 36 and high resolution. Whenever it renders on a single machine it finishes, however, it takes 8 days to complete. Using the net render it gets to 1.2% and crashes. Do you have any suggestions to make the net render more stable, or to speed up the rendering on a single machine. If we are rendering at 300DPI what is a suitable image size to render. Any help to speed this process up would be helpful. Thank you!
    Design Visualization Moderator stusic's Avatar
    2004-10
    N32° 32' 19.08", W-84° 52' 59.03"
    1,279
    Default Re: Distributed Bucket Rendering
    To print a 24"x36" image at 300dpi, you'd need to render the image at 7200 pixels x 10,800 pixels.
    Can you post the render settings, either by listing them or a screenshot?
    Do you have problems rendering smaller jobs on your farm?
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Administrator, Heatcraft RPD
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    2009-10
    3
    We have no problem rendering smaller images. My render settings are 5400 x 8100 at 300DPI.
    2004-10
    1,279
    Can't read the render setting in the screenshot, but 8 days seems like a lot - even for a large image.
    *EDIT*
    You said you don't have problems rendering smaller images - is that when rendering on your farm?
    Phillip Bradshaw
    2009-10
    3
    Rendering farm is ok on small images, but slower than single machine. The render settings are:
    image precision - High
    Final Gather - High
    Glossy Reflections - 2.0X High Quality
    Glossy Refractions - 2.0X High Quality
    FG Bounces - 3
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Your machine you use to do most of your design sounds like a sweet setup.
    Do the other machines have the same amount of RAM on them? If not, they will choke when assigned to help on the job.
    The system used to originate the job will set the amount of data to process based on the available amount of RAM. 3ds MAX assumes all other systems on the farm have the same amount of RAM. If they have less, then they don't have enough to finish the job.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2004-05
    4,627
    Also, are you using Distributed Bucket Rendering (DBR) via the Render Setup Dialog?
    OR
    Using Backburner to process the image?
    I've heard that Backburner can provide greater stability than DBR.
  1. scheduling distributed families
    By ddenton in forum Revit Architecture - General
    Last Post: 2009-07-07, 05:35 PM
  2. Distributed Bucket Render Farm
    By bowlingbrad in forum 3ds Max - General
    Last Post: 2009-05-21, 04:01 PM
  3. Distributed rendering
    By chris.bolton in forum Revit Architecture - General
    Last Post: 2008-08-01, 03:39 PM
  4. How do I set up VRay/Max 9 distributed rendering
    By depth3d in forum 3ds Max - General
    Last Post: 2008-06-06, 06:47 PM
