Thread: Proper Settings for AUTOCAD 2010 on 64BIT Machine?
    2007-07
    3
    Thumbs down Proper Settings for AUTOCAD 2010 on 64BIT Machine?
    If anyone can help me out with the proper settings for AutoCAD 2010 on a 64-bit machine I would greatly appreciate it. This is my first 64-bit machine I have worked on and am not familiar with it, nor do I know what I need to tweek to get it to work properly. It is a brand new machine with Windows XP64. Revit Structure 2010 runs incredibly well on it with no tweeking at all. AutoCAD 2010, however, takes forever to open tool palettes, takes a lifetime to manipulate layers, and runs very slow in general. Anyone with the same problems? Thank you in advance for any help you can provide.
    Earth
    9,803
    Default Re: Proper Settings for AUTOCAD 2010 on 64BIT Machine?
    I just installed vanilla AutoCAD 2010 on Windows 7, 64-bit and it runs great so far. No problems.
    Have you tried disconnecting all network connections (including wifi) as a test?
    R.K. McSwain | CAD Panacea |
    0,0,0 The Origin
    8,570
    Exactly as above.
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    622
    You can start autocad without your profile to make sure there isn't something in there causing problems. Copy the startup icon on the desktop, change or add a profile switch like /p newprofile in properties of the icon.
    Example.
    "C:\Program Files\Autodesk\ACAD_2010\acad.exe" /p newprofile
    2005-02
    Ottawa, KS
    45
    In Options, under the Open/Save tab, uncheck the Maintain Visual Fidelity box. This should help speed some things up. It did for me. The event reactors that Autodesk keeps putting in the program are a nice thought, but when they are running, whenever you make a change, they check the entire drawing to make sure everything is still okay. The Layer Properties Manager is especially notorius for this. Hope this helps some.
  1. 2009: Migrate settings machine to machine
    By Bill.Jensen in forum ACA General
    Last Post: 2014-05-01, 02:37 AM
  2. AutoCAD 2010 on 64bit Machine
    By Spenner in forum AutoCAD General
    Last Post: 2011-07-02, 11:53 PM
  3. AutoCAD Map 3D 2010 64bit - Oracle spatial advanced support ?
    By jprichard in forum AutoCAD Map 3D - General
    Last Post: 2011-06-23, 02:23 PM
  4. Proper Autocad settings for Nvidia card
    By brad.261295 in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-09-29, 07:28 PM
  5. CIVIL 3D 2010 OBJECT ENABLER FOR ARCHITECTURE 64BIT 2010
    By yangcheng2008 in forum AutoCAD Civil 3D - Grading
    Last Post: 2009-06-17, 01:34 PM
