Results 1 to 10 of 19
Thread: Formula help please
    2008-10
    279
    Default Formula help please
    Hi all,
    I'm afraid I don't understand these conditional statements at all - and yes I have read the useless summary in the help file (they need to add a visual real world example, not just a bunch of hypothetical numbers...)
    I would like to make a void height parameter which will always be taller or as tall as 3 solid elements which have variable heights.
    So I want this void to always match the height of whichever solid is tallest at the time.
    In non-mathmatical terms, I need something like:
    Void height = The greatest of either A height, B height or C height
    Help would be great : )
    Cheers
    2008-10
    279
    Default Re: Formula help please
    Could an IF statement work?
    Void Height = IF(A>B or C, A, B or C) (B>A or C, B, A or C) (C>A or B, C, A or B) ???
    I guess you can't have 'or' in a formula?
    My brain hurts...
    AUGI Addict jsteinhauer's Avatar
    2015-11
    Madison, WI
    1,317
    Lightbulb Re: Formula help please
    You're formula doesn't make a lot of sense to me, because I don't know which one to pick, B or C. Revit my also be thinking (Which one do you want, 'B' or 'C'). You might try something similar to 'If(A>(B or C), A, B)'.
    Hope this helps,
    Jeff S.
    All AUGI, all the time Munkholm's Avatar
    2006-09
    The Kingdom of Denmark
    560
    Jeff.
    I´m to tired to figure out how to do this in one line of formula, but it´s fairly easy, when using an extra calculation parameter
    Calc 1 = if(Solid A > Solid B, Solid A, Solid B)
    then
    Void Height = if(Calc 1 > Solid C, Calc 1, Solid C)
    Well, just look at the attached, and see for yourself
    - Klaus Munkholm
    All AUGI, all the time Ning Zhou's Avatar
    2006-08
    613
    try that, not tested, 0.0 value is just a junk number (can be any number) because it will never be a case.
    H = if(or(A > B, A > C), A, if(or(B > A, B > C), B, if(or(C > A, C > B), C, 0.0)))
    2006-08
    613
    logically you also have to think the equal cases, like below:
    H = if(or(A > B, A > C, A = B, A = C), A, if(or(B > A, B > C, B = A, B = C), B, if(or(C > A, C > B, C = A, C = B), C, 0.0)))
    2006-09
    560
    Joe.
    Just tested your suggestions, but in either case it´s not working when "C" is the greatest.... Been strugling my brain with it, and really dont see a way to do it, with just one line of code - It´s possible to test for several different conditions IF, AND, OR - but only possible to return a value for false, and one for true...
    - Klaus Munkholm
    2006-08
    613
    right, seems using "and" is more logically sound, try following to see if it works:
    1) no equal cases allowed
    H = if(and(A > B, A > C), A, if(and(B > A, B > C), B, if(and(C > A, C > B), C, 0.0)))
    2) equal cases also considered
    H = if(and(or(A > B, A = B), or(A > C, A = C)), A, if(and(or(B > A, B = A), or(B > C, B = C)), B, if(and(or(C > A, C = A), or(C > B, C = B)), C, 0.0)))
    again, not tested, give me a shout if it works.
    if it still doesn't work, then using family API will be a way out, i haven't tried API at family level yet.
    2006-09
    560
    Joe.
    1) Works, unless there´s two equal numbers, then "0" is returned as the value.
    2) Works like a charm So I stand corrected !
    - Klaus Munkholm
    2008-10
    279
    Hi guys,
    Thanks very much for all the input
    None of it makes much sense to me at first glance though... Like I said, I really don't get these statement formulas yet.
    I shall put my mathemetician hat on and have a play though.
    Thanks again
  1. 2013: How to use this Formula,"Formula That Returns Strings"?
    By mike99 in forum Revit Architecture - General
    Last Post: 2013-01-09, 06:28 AM
  2. Yes/No Formula
    By lonewolfjustin in forum Revit MEP - Families
    Last Post: 2009-06-05, 12:21 AM
  3. Formula Help
    By stelthorst in forum Style Management
    Last Post: 2008-03-25, 05:07 PM
  4. Formula Use
    By jkrager in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-01-20, 06:57 PM
  5. = a formula
    By GuyR in forum Revit Architecture - General
    Last Post: 2005-03-11, 08:24 AM
