Thread: data link/ database field help
    2007-08
    8
    Default data link/ database field help
    Hello!
    Am really hoping someone can help me. Am not sure if this is the right forum or not....? [moved to Fields forum]
    I have 3 questions about database fields.
    1. Does anyone have any experience with them and could give me hints as to pit falls. Or should I just not even go down that road...?
    2. Have been experimenting with ODBC/ DSN files with moderate success. For some reason I cannot remove files to which I did test connections to from the drop down in the Fields window. (see jpeg) How to remove them?
    All ideas are welcome.
    Have good days all of you!
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    Default Re: data link/ database field help
    For your second question: have you tried the DataLinks command?
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2007-08
    8
    Hello!
    Yes I have tried but only get me to links to excel not database links....
    And have checked in options where Data Links are stored and cleared that folder. hm
    2007-07
    Jo'burg SA
    4,344
    2007-07
    Jo'burg SA
    4,344
    As for hints and pitfalls. A few I've come across:
    • In some cases formatting numbers don't work.' Workaround is to hack the field-codes in a text editor and copy-n-paste into the MText; or use a nested field inside a formula field.
    • Both workarounds above break if you edit the field at a later stage.
    • Use diesel fields to work with strings, e.g. to extract a portion of the drawing's filename you use $(substr,$(getvar,dwgname),2,3). 2 being the start position, and 3 the length to be extracted - change as needed.
    • You cannot use nested fields inside a diesel field. You can paste another field's code into the diesel, it appears to work. But after clicking OK the nested field is converted to normal text - i.e. wont update.
  1. Field data lost at data link synchronization
    By brennsvette in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-09-17, 03:07 PM
  2. External Database Link.....Total Noob.....Need help
    By jmeyer.186809 in forum AutoCAD Map 3D - General
    Last Post: 2008-06-24, 04:50 PM
  3. Link Fields to Oracle database
    By ted.evans in forum ACA General
    Last Post: 2007-04-26, 02:07 PM
  4. Schedule data to Database
    By ted.evans in forum ACA Wish List
    Last Post: 2007-02-21, 07:29 PM
  5. Link Text Fields to Database
    By kerickson in forum AutoCAD Fields
    Last Post: 2006-02-02, 10:03 PM
