Results 1 to 10 of 10
Thread: Bad Fonts ( Arabic Fonts)
    100 Club moshira_hassan's Avatar
    2003-01
    133
    Exclamation Bad Fonts ( Arabic Fonts)
    I have bad result in printing when using windows arabic fonts like arabic transparent or arial ( not Acad fonts)... they appear well on screen but the scrabbled when printed .... any idea how
    2005-05
    29
    Default Re: Bad Fonts ( Arabic Fonts)
    Hi
    This is beacuse of the plotter/printer settings.
    in Plot dialog box
    1- Select the Printer/Plotter then
    2- Properties
    3- Device and Documnent Settings Tab
    4- Click on (+) next to Graphgic then True Type Text
    5- Choose True Type as Graphic
    6- OK
    7- This option for this job only
    8- This option to create a perminant proter settings to use next times
    9- Ok to go back to Ploting dialoge box
    Regards
    2003-01
    133
    I don't know why it didn't workswith me ...I've attached the pdf and the original finel maybe I'm missing something
    2007-04
    60
    Hi
    This happen because you used English font I think you do just alt+ lift shift and write Arabic , So please used this font for Autocad
    2005-05
    29
    it works with me
    see attached
    any way try to use the arabic fonts which e.mounir attched
    to use the fonts files
    close autocad
    copy and paste this 2 files in autocad font folder
    for ex. C:\Program Files\AutoCAD 2007\Fonts
    then create a new textstyle and coose this font
    PS. I have more font files if you want I'll send you.
    Hasan
    2005-05
    29
    tryout this solution
    1.) Close all programs
    Go to Control panel| Regional and language settings
    Languages tab
    Select "install files for complex script and right to left languages (including Thai)
    Requires a reboot
    and in printer properties Choose True Type as Text
    2003-01
    133
    I didn't find that exact option in language tab but found another one ( attached ) but didn 't work too ... I'm using ain XPSP2 .
    Quote Originally Posted by hasancad View Post
    Languages tab
    Requires a reboot
    2005-05
    29
    Its installed (see attached)
    eeeemmmmm
    - did you create a new PC3 file for the printer and use it?
    PS: at first reply in attached image In step no 5 choose True Type as a text not as a Graphics
    - Try to print the same file using another PC.
    Hasan
    2003-01
    133
    It finally works .. thanks ...
    ps. for my HP 500 plotter i had to send file as bmp map not sending it directly to plotter ....
    2010-06
    Thanks a lot... it's a big help to find the solution on my problem...
  1. Using Arabic Fonts
    By samelangovan in forum AutoCAD Plotting
    Last Post: 2013-03-18, 11:41 AM
  2. 2011: Arabic Fonts Problems
    By aksalaymeh in forum ACA General
    Last Post: 2011-04-30, 04:39 AM
  3. Different fonts have started showing up as default AutoCAD fonts
    By jackie.112886 in forum AutoCAD General
    Last Post: 2006-05-15, 11:02 PM
  4. DWF loses protected fonts - download fonts option?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2006-03-25, 12:01 AM
  5. shx fonts to true type fonts
    By sbrown in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-03-31, 02:53 PM
