Beancud
Has anyone noticed in 2010 you Revit want let you draw duct above 1000 mm?
now before you shout out "mechanical settings!" the setting is fixed to support larger ducts.
From the properties ribbon I can't seem to enter any duct size above 4 digits... and when I slide it to 1000< it want select it....
This is for both existing duct, or newly drawn duct... Revit want let me draw a duct size above anything with 4 digits.
The only way to draw a duct above 1000< is to manually select each duct and change in instance properties. I've tested this out on tees/taps, new project, old, no avail... am I missing an update or something to fix this?
