Thread: Independantly rename floor plan and reflected ceiling plan views?
    2009-02
    Honolulu
    129
    Default Independantly rename floor plan and reflected ceiling plan views?
    Can you rename these independently from each other? It seems that when we rename the reflected ceiling plan views to read, "FIRST FLOOR REFLECTED CEILING PLAN" this will also rename the FIRST FLOOR PLAN to read the same as the reflected ceiling view label.
    Pittsburgh, PA USA
    1,906
    Default Re: Independantly rename floor plan and reflected ceiling plan views?
    Quote Originally Posted by rob.209068 View Post
    When you go to rename them, I should be asking if you want to rename the Level. Answer that NO. Then you should be able to rename them separately.
  1. 2014: Reflected Ceiling Plan Vs Plan view ---> direction up
    By Craig_L in forum Revit Architecture - General
    Last Post: 2015-09-08, 08:28 AM
  2. 2012: Linking Reflected Ceiling Plan views
    By trialbyfire in forum Revit Structure - General
    Last Post: 2012-06-08, 05:53 PM
  3. 2012: Reflected ceiling plan (RCP) inside a plan region
    By barbara.ivo557941 in forum Revit Architecture - General
    Last Post: 2011-08-18, 02:16 PM
  4. Reflected Ceiling Plan Views
    By jdodge2 in forum ACA General
    Last Post: 2008-09-02, 07:55 PM
  5. Reflected Ceiling on Floor Plan?
    By JohnASB in forum Revit Architecture - General
    Last Post: 2004-10-11, 10:44 PM
