When I publish to pdf in 2010, I sometimes get a message stating that it cannot find ArielMT. I can't find this font either. This only happens with structural notes that I imported from a Word document.
Any ideas?
Any ideas?
It's usually spelled ArialMT - is that what you want?
It's a variation on Arial that includes some Unicode characters.
Arial is/was shipped with Windows, ArialMT is/was shipped with versions of Acrobat.
Both are freely available for download.
John B
"With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
To avoid any further font issues change the font in the Word document by selecting the copied text and change the font to a desired common font like Tahoma and save as if you prefer, then you may have to purge your drawing before copying and pasting again.
Less is only more where more is no good. - Frank Lloyd Wright
Got it, thanks.
Hey John, what did you do to fix your issue?
We have a similar issue here that gives me the missign font error when plotting to dwf. Could it be text pasted from word? We use Arial in word and when I paste it into an AutoCAD mtext box I convert it to Arial Narrow, which is our chosen font in AutoCAD. If I changed it after pasting, why the issue?
Tim McDougald
CAD/BIM Manager / Assistant P.M.
KMB Design Groups, Inc. P.S.
828 7th Avenue SE - Olympia, Washington 98501
HayWire Racing
1101 124th Street South, Suite B - Tacoma, Washington 98444
I get the same error when i publish or print to PDF any document with a degree symbol or center symbol.
The entire text block was created in autocad and the special character was inserted by using %% ie 45.6 %%DC, %%C45.8mm
so any solution to fixing this?
my current work around, publish to DWF then switch computer (where adobe is installed) then print from DWF to PDF.
I would like to print straight to PDF from AutoCAD.
