Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: BIM Standard and BIM Example Drawings Sharing
  1. #11
    2009-02
    4
    Default Re: BIM Standard and BIM Example Drawings Sharing
    HI,
    been collecting BIM Standards for a while. Here a list of about 40 of them from all over the worlds that you might find helpful
    Here
    http://www.cad-addict.com/2013/02/li...standards.html
  2. #12
    2001-12
    St. Louis
    5,407
    Quote Originally Posted by marti View Post
    HI,
    Here
    That is a fantastic table of resources.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  3. #13
    2012-08
    14
    Hey Marti
    Thanks for posting that, a good collection of links giving some useful info on the subject. I'll check to see if I have anything else you could add to your list.
  4. #14
    2010-11
    13
    If you are looking for linestyles according to the european standards (ISO 128:20 ), have a look on the following website: http://www.archigrafix.com/technical...so-128-20.html
  5. #15
    2011-05
    926
    Of all those standards mentioned in the list, in the USA, the only potential for a national standard is NBIMS. The others listed are for specialty uses and not necessarily of value to the entire market. The USACE is one primary example of that.
    The NBIMS does not cover 2D output at this time. In that case, most people refer to the appropriate sections of the National CAD Standards. In the next release of the two documents, they will be coordinated so as to be complementary to each other, without having conflicts. The NCS has been around since well into the last century, so its contents are tried and true. Both documents reflect a consensus of hundreds of practitioners from all corners of the BIM/CAD world.
  6. #16
    2011-09
    2
    Send me your email account than I can sent a couple of drawings we created form a detailed design Revit model (mainly MEP)
  7. #17
    2009-01
    2
    thank you one and all for all you information
  1. GS104-2: Sharing Drawings Using Map 3D
    By Autodesk University in forum Geospatial
    Last Post: 2013-05-05, 01:32 PM
  2. CD22-2: Only DWF Will Do for Sharing CAD Drawings Effectively
    By Autodesk University in forum Collaboration
    Last Post: 2013-04-17, 04:11 AM
  3. Sharing camera views between drawings
    By cad user in forum AutoCAD General
    Last Post: 2007-01-24, 02:33 AM
  4. Suggestions on Sharing Drawings
    By kathy.miller in forum CAD Management - General
    Last Post: 2006-01-18, 02:28 AM
  5. Sharing dwg drawings with Mac users.
    By cindy.dangles in forum DWF Viewer - General
    Last Post: 2005-01-11, 09:29 PM
