Thread: Solid filled regions print always black
    2009-04
    London, UK
    146
    Default Solid filled regions print always black
    Hi,
    We are using Revit 2010 on Windows 7 and have the following problem.
    Not matter what colour we apply to a solid filled region the print out is always completely black. (In the print setting we use 'black lines' as colors.)
    Now, if I override the color properties of a single filled region (by element) it is printed in the correct way?
    Any help would be mostly appreciated.
    Regards,
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Default Re: Solid filled regions print always black
    If you want colours to come through don't use black lines because it will make everything black. Rather leave it on colour.
    2009-04
    London, UK
    146
    Hi Elmo,
    Ive attached two pdf-files to clarify the problem we have a bit more in detail.
    Please note that both pdf files were created using the same print setting (color: 'black line')
    The 'wrong' file shows that the filled region gets printed completely back although the color is exactly the same as being used for the wall hatch.
    The 'correct' file shows how it should look like but I only achieve this in overwriting the element properties (by element) in the current view. (Funny enough the color Im using to overwrite it is excatly the same as the one being use in the first place when creating the filled region...
    Any thoughts on this?
    Regards,
  1. 2013: Solid Black Filled Region not visible
    By mfox396859 in forum Revit Structure - General
    Last Post: 2013-07-22, 05:57 PM
  2. Solid Black "Filled Region" Does Not Print
    By RafeRedmond in forum Revit Architecture - General
    Last Post: 2008-09-10, 06:30 AM
  3. Shadows and solid Filled Regions
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2007-06-27, 02:00 PM
  4. "White" filled regions print Black???
    By jabberwoki in forum Revit Architecture - General
    Last Post: 2004-06-30, 07:00 PM
  5. Filled Regions Still Plotting Black...
    By BillyGrey in forum Revit - Plotting/Printing/Exporting
    Last Post: 2004-05-05, 08:50 PM
