Thread: Revit link when exporting to .dwg
    2009-11
    15
    Default Revit link when exporting to .dwg
    I have been working on exporting to .dwg and have found that revit seem to differ in how it handles links. Sometimes they appear as blocks in the exported .dwg which is the output i want so i do not have to bind them. But sometimes it decides to create xref's in the same folder and load them in. Any ides on how to always have them as blocks? It seems to be completely random as to weather it creates a block or xref's?
    2009-02
    Houston
    686
    Default Re: Revit link when exporting to .dwg
    It is not random. When you are in the export dialogue there is a check box at the bottom of the window that asks whether you want to xref views on sheets. I know this doesn't seem to apply, but you'll see that if you check the box to xref views then rvt links will be exported to a separate cad file. However, if you uncheck this box then rvt links will not be exported to a separate file.
  1. Revit Arch Link Exporting to CAD...
    By cris8096 in forum Revit MEP - General
    Last Post: 2012-05-01, 08:45 PM
  2. Replies: 0
    Last Post: 2012-01-11, 09:42 PM
  3. Revit Structure to Revit Architecture link question
    By chris.spenski in forum Revit Structure - General
    Last Post: 2009-05-15, 03:05 PM
  4. Revit Exporting
    By Tyveka in forum Revit Architecture - General
    Last Post: 2009-02-07, 06:04 AM
  5. Revit Architecture Link in Consultants Revit Structure
    By mjward1 in forum Revit Structure - General
    Last Post: 2008-05-28, 09:28 PM
