Thread: Revit Export Issue: Failed to Export Image
    2009-10
    8
    Default Revit Export Issue: Failed to Export Image
    Hello,
    I've come across the following issue when I'm trying to export my current project(views,plans,sections,etc) as a jpg/png/etc: "Failed to Export Image.Please reduce image size"
    I want it to be exported at real project scale 1:100 so my Image Size is set to Zoom to 100% of actual size and Raster Image Quality is set to 300.I'm planning on importing the JPG into Photoshop since they will be for a presentation.
    Thank you!
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Cool Re: Revit Export Issue: Failed to Export Image
    I suspect an insufficient omount of memory is causing this.
    How much RAM do you have on the machine which is trying to export the image?
    You mey need 8 GB or more for this.
    Also, I assume that a large image size as you describe is also trying to create a very
    large file, at 300 dpi--which in turn is causing the lack of memory problem.
    Try a slighty lower quality--say 150 dpi--which should be more than enough for that large an image.
    cheers.........
  1. 2014: How to Export an Imported Image File from Revit.
    By marudhu@revit.com in forum Revit Architecture - General
    Last Post: 2013-11-18, 04:53 PM
  2. Export Revit license failed - 'max no of exports reached...'
    By ws in forum Revit Architecture - General
    Last Post: 2010-02-13, 08:14 PM
  3. Export to DWF Failed
    By cboss in forum NavisWorks - General
    Last Post: 2008-09-25, 03:48 PM
  4. Revit 2008 API: Import/Export of DWG/DWF/Image?
    By Dave Lewis in forum Revit - API
    Last Post: 2007-03-24, 11:55 PM
  5. Failed to Export Image Error
    By artitech in forum Revit Architecture - General
    Last Post: 2005-07-04, 01:07 PM
