Is there a way that I can schedule a detail component family????
Quick run down on what I am trying to do:
I embed 2 SHARED parameters into a detail component. I place said component in views as needed and I input values into these parameters (1 is a Type parameter and 1 is an instance parameter, therefore one will always be the same and one will always vary).
When I create a schedule, I add the 2 SHARED parameters to the list and filter it as "Parameter Exist". When I hit okay and go to the schedule, the parameter names appear in the header but nothing appears below in the "schedule" portion. When I tag the detail component the custom "multi-category" tag reads and displays both parameters without a problem.
I know you do not have to tag an object for it to be appear in a schedule, however in this instance I think if you could schedule a tag I could get this to work.
From what I am seeing it is not possible to schedule a detail component. Am I correct in assuming this or am I completely missing something.
Josh
