Thread: Pipe Types - Define Tee AND Tap?
    2008-09
    91
    Smile Pipe Types - Define Tee AND Tap?
    Is there a reason to define both a tee and a tap for a pipe type? It seems that by picking a preferred junction type that is the only one that gets used.
    I suppose my underlying question is this: is there a way to have Revit pick a tap instead of the preferred tee junction given the main and branch pipe sizes? In particular, if the difference between the main and branch size is large I'd like a tap instead of a tee (e.g. given a 14" main and a 4" branch - tap, 14" main and branch - tee)
    And for that matter, there isn't a pipe tap in the OOTB content? And I didn't see tap as a fitting type in the family category for pipe fittings? Are pipe taps even possible?
    All AUGI, all the time Jrobker's Avatar
    2005-08
    11,000 feet atop a chute
    956
    Default Re: Pipe Types - Define Tee AND Tap?
    No.
    You cannot define fittings dependent on pipe/duct size.
    JR
    "Keeping my view range hopeful."
    I could stop if I wanted to RevitNinja's Avatar
    2007-09
    473
    Create a Pipe type with a tee and name it as such.
    Then duplicate it, change the preferred tee to a tap, and edit the name to reflect that.
    You will have a choice of pipes in the type selector when you click the Pipe tool.
    2012-02
    is that the only way? is it not possible realize that with a shortcut?
  1. How to organize pipe types
    By Joe Fields in forum Revit MEP - General
    Last Post: 2012-07-12, 12:11 PM
  2. Download Pipe Types
    By bishop295808 in forum Revit MEP - General
    Last Post: 2011-12-02, 01:21 PM
  3. problem with pipe types
    By JAC.95598 in forum Revit MEP - General
    Last Post: 2010-05-07, 06:44 PM
  4. Using Wye connection as default for certain Pipe Types
    By kap_78 in forum Revit MEP - General
    Last Post: 2010-03-17, 09:58 AM
  5. Rendering Pipe Types by flow stream
    By kmcglothlin in forum Revit MEP - General
    Last Post: 2009-12-18, 02:06 PM
