Results 1 to 10 of 15
Thread: Extracting Metadata from a .DWG
    2009-12
    7
    Exclamation Extracting Metadata from a .DWG
    Hi there,
    I have been given a task by work to figure out a way of extracting metadata from a .dwg so that the information can be inputted into an application that is being developed.
    It is my understanding that a .DWG is purely an image with attributes and there is no metadata, however there is text information in each .dwg that i need.
    I have 15,000 drawings to sift through and manually viewing each one and noting the information down i.e drawing number, location etc etc would be an extremely tedius job that would take far too long.
    Does anyone have any ideas how i can do this? preferably with a batch application.
    I have had a look on google and have found a few applications that would be able to extract information (attributes) but none that extract the information that i actually need.
    Any help would be greatly appreciated,
    Thanks very much
    Nick
    Houston
    7,543
    Default Re: Extracting Metadata from a .DWG
    What information are you trying to catalog? You mentioned the drawing number, location, etc.
    Would something like this work?
    http://www.dotsoft.com/demos/tpdwgcatgen.htm
    2009-12
    7
    Exclamation Re: Extracting Metadata from a .DWG
    The application could potentially work, just trying to get a free trial to give it a go,
    Thanks very much for your help,
    Nick
    0,0,0 The Origin
    8,055
    Quote Originally Posted by nicholas.amphlett View Post
    Just FYI, a DWG file is actually a database, not an image.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2009-12
    7
    I have tried to get in contact with that company about a trial of there product but i have had no response,
    In response to the question about what information i require, when you open up a dwg drawing there is borders around the drawing itself and on the right hand side (i think) there is information such as drawing number, location, client address etc etc - that is the information that i need to get from 15,000 dwg's.
    Does anyonbody else have any other ideas please?
    Thanks again,
    Nick
    0,0,0 The Origin
    8,055
    When acad opens a dwg file it reads the contents of the (database) file and generates graphical elements (lines, circles, text) accordingly.
    You could check to see if the information has been saved as metadata by right-clicking, one at a time, on each of a few files, selecting Properties and seeing if there is any information on the Summary and Custom tabs. I doubt that there will be.
    You could save each file to the DXF format, open them in a text editor (Wordpad) and search for the info you want but that would take forever even for a few files.
    You need to automate that process (in effect if not it fact) and the best place to start would probably be in the programming forums.
    John B
    2009-12
    7
    Quote Originally Posted by jaberwok View Post
    Thanks alot for your response, i have tried your recommendation and it is definetly not an efficient way of doing this.
    Keep the ideas coming though guys! Really appreciate it!
    Thanks again
    Nick
    Just noting that at the time you posted this it had been roughly 21 hours since your email.
    Assuming ALL these drawings are consistant with that information in a block insert it would fairly easily be harvested, possibly by tools built into AutoCAD. If it's random text it would provide more of a challenge. That is the first determination you will need to make.
    2009-12
    7
    Hey Dotson,
    Further to our telephone conversation i have checked with the department that deals with DWG's. They have advised that the majority of the drawings are consistent however the text that is required is "completely separate from the rest of the drawing" - they are not attributes - with that in mind they also advised that there would be no efficient way within AUTOCAD to get this information and the only solution they say would work is to hire some temps to go through the drawings and manually input the text needed.
    Thanks again,
    Nick
    0,0,0 The Origin
    8,055
    Hey Dotson,
    Thanks again,
    Nick
    If Terry Dotson says it can be done, it can be done.
    John B
  1. Help needed: Linking Sheet Parameters to PDF Metadata
    By jonasoverby in forum Revit - Plotting/Printing/Exporting
    Last Post: 2011-11-11, 09:46 AM
  2. Synchronized (FTP) DWG files lose their metadata
    By Duncan Lithgow in forum Networks
    Last Post: 2008-09-25, 08:54 PM
  3. Change metadata (Sheet Properties) for DWFs
    By Andrew Dobson in forum Design Review - General
    Last Post: 2008-08-14, 11:59 AM
  4. Revit's Next Big Thing - Metadata
    By mibzim in forum Revit Architecture - General
    Last Post: 2007-08-22, 05:25 PM
  5. XML Metadata
    By td729 in forum AutoCAD Map 3D - General
    Last Post: 2005-04-02, 03:21 PM
