Thread: Object Styles
    2009-10
    5
    Default Object Styles
    The pad footings and wall footings come in as solid lines by default. When I go into object styles and change the solid lines to dashed lines, they still remain solid in the project. What do I have to change in order to make my footing lines dashed?
    2008-04
    270
    Default Re: Object Styles
    Check for any visibility graphic overrides within the view - by element and by category. If this is the case then anything you change within object styles will be ignored.
    You will need to reset the override and it should appear correct.
    Regards
    2009-10
    5
    Thanks for the tip. I went back and checked and nothing is over ridden. I did see while the dashed lines are not showing up in the plan view, the footings ARE showing up dashed in the 3d view.
    Any other suggestions?
    2008-04
    270
    Strange....
    Are the foundations joined to anything? I.e. a floor slab?
    2008-04
    270
    Try typing the shortcut LW and selecting <By Category> for the line type, then click on each of the foundations lines.
    Maybe someone has manually overridden the line type.
    Regards
    2007-03
    Rock Island, IL
    114
    Are you using phases in this project? It may have something to do with the graphic overrides for the element's phase status (existing, demo, new etc.). We had our existing elements set to solid lines for the longest time.. (how annoying!)
  1. 2015: Object Styles and Line Styles and Patterns
    By kROSEMAN in forum Revit Structure - General
    Last Post: 2015-01-12, 10:47 AM
  2. 2014: Two families - same object styles and line styles - different results
    By CADMama in forum Revit Architecture - Families
    Last Post: 2014-10-07, 08:02 PM
  3. Object Styles / Line Styles
    By gautamrs in forum Revit Architecture - General
    Last Post: 2007-01-24, 01:28 AM
  4. can you have different object styles?
    By CADBIMManager in forum Revit Architecture - General
    Last Post: 2005-04-21, 04:54 PM
  5. Link Text with Object Styles & Line Styles
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2004-07-15, 04:27 PM
