Thread: Deleting Dimension Styles
    2009-07
    3
    Default Deleting Dimension Styles
    Hi.
    I'm working on a template for our office and would like to know how to delete unused dimension styles. I can't find them in settings, families nor in purge unused and I've tried searching the web for answers. (Including AUGI...)
    Any help would be much appreciated,
    Regards,
    Artturi Björk
    2006-01
    4,516
    Default Re: Deleting Dimension Styles
    Quote Originally Posted by artturi.bjork View Post
    Hi.
    Regards,
    Artturi Björk
    They show up under purge unused.... But theyre probably used. Draw a new dimension of the style you want to get rid of. Then right click and select all instances. Go to the filter and see how many there are.
    Change them to the one you want to keep, and go back to purge...
    2005-02
    44
    I'm having the same issue, but that fix doesn't work. When I select all instances, it only shows one item selected. Could there be a family in the template that uses this style? What's the easiest way to track this down?
    2005-02
    44
    Actually, after more testing "select all instances" is only finding the dimensions placed within the model and not any placed in legends, etc.
  1. 2013: Deleting Object Styles Category
    By jboersema in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-10-17, 05:56 PM
  2. Replies: 3
    Last Post: 2007-02-24, 03:50 PM
  3. Sharing standard Dimension styles, text styles, hatch patterns, etc
    By dhavalpatel_us337373 in forum AutoCAD General
    Last Post: 2007-02-02, 08:34 PM
  4. deleting text styles
    By tect75 in forum Revit Architecture - General
    Last Post: 2006-10-11, 05:52 AM
  5. Deleting or renaming line styles
    By dhurtubise in forum Revit Architecture - General
    Last Post: 2006-04-03, 08:04 PM
