Thread: multi leader text alignment
    2009-04
    78
    Default multi leader text alignment
    Here is the situ:
    Draw a leader with mtext , or multileader where the leader attaches to the text on the right. Set the text to "left justify". Draw a vertical construction line at the left anchor of the text. Now change the text to somethin shorter. You will see the text adjust itself to the right.... this is called "right hand justification" ... Is there any way to get the leader to text to stay actually stay in 'left justify' when editing? (i.e. the left anchor of the text remains stationary while the leader adjust to the new text length)
    -R
    2011-09
    Default Re: multi leader text alignment
    Hi, Sorry i dont have the answer, but i have the same issue, I would like to use multi leaders, as it would be a time saver over what i do now, but without this function its not.
    Guy
  1. multiple connection point for leader tails when using a multi-leader
    By jschraud228486 in forum AutoCAD Annotation
    Last Post: 2010-06-16, 01:42 AM
  2. Text Height of multi leader
    By cadman_meg in forum AutoCAD General
    Last Post: 2008-08-19, 03:51 PM
  3. multi leader text box
    By bowtle in forum AutoCAD General
    Last Post: 2007-07-25, 04:45 AM
  4. Leader alignment
    By mlgatzke in forum Revit Architecture - General
    Last Post: 2003-12-22, 06:32 PM
