prin1
(prin1 [expr [file-desc]])
Arguments
expr A string or AutoLISP expression. Only the specified expr is
printed; no newline or space is included.
file-desc A file descriptor for a file opened for writing.
Return Values
The value of the evaluated expr. If called with no arguments, prin1 returns a
null symbol.
Returns the UCS 3D point at a specified angle and distance from a point
Prints an expression to the command line or writes an expression to an open file
142 | AutoLISP Reference
Used as the last expression in a function, prin1 without arguments results in
a blank line printing when the function completes, allowing the function to
exit “quietly.”
Examples
Command: (setq a 123 b '(a))
(A)
Command: (prin1 'a)
AA
The previous command printed A and returned A.
Command: (prin1 a)
123123
The previous command printed 123 and returned 123.
Command: (prin1 b)
(A)(A)
The previous command printed (A) and returned (A).
Each preceding example is displayed on the screen because no file-desc was
specified. Assuming that f is a valid file-descriptor for a file opened for writing,
the following function call writes a string to that file and returns the
string:
Command: (prin1 "Hello" f)
"Hello"
If expr is a string containing control characters, prin1 expands these characters
with a leading \, as shown in the following table:
Control codes
Code Description
\\ \ character
\" " character
\e Escape character
\n Newline character
\r Return character
\t TAB character
\nnn Character whose octal code is nnn
princ | 143
The following example shows how to use control characters:
Command: (prin1 (chr 2))
"\002""\002"
SEE ALSO “Displaying Messages” in the Visual LISP Developer’s Guide.
princ
(princ [expr [file-desc]])
This function is the same as prin1, except control characters in expr are
printed without expansion. In general, prin1 is designed to print expressions
in a way that is compatible with load, while princ prints them in a way that
is readable by functions such as read-line.
Arguments
Return Values
The value of the evaluated expr. If called with no arguments, princ returns a
null symbol.
print
(print [expr [file-desc]])
This function is the same as prin1, except it prints a newline character before
expr, and prints a space following expr.
Arguments
Prints an expression to the command line, or writes an expression to an open file
144 | AutoLISP Reference
Return Values
The value of the evaluated expr. If called with no arguments, print returns a
null symbol.
