Our project has 2 walls joined at 90 degrees and we would like to create a window where the glass comes together at the intersection without a frame/mullion (butt joint). Is there anyway to do this? I'm working in 2007. Thank you!!!
I'm going off memory here, but try this:
Create a custom door / window assembly. On the design rules tab, go to the frame assignment and turn off one of the frames (either left or right).
Place it in the wall and mirror it at the corner to get the window on the adjacent wall.
Use the subtraction body modifier on the walls to remove the corner. It's not perfect, but it works sorta. lol
Or go here on the Adesk website. The second one describes how to do corner windows.
http://www.autodesk.de/adsk/servlet/...linkID=9240658
Wonderful. I believe I got it to work. Thank you!
