View Poll Results: Opinion of the current Revit backup solution
Voters
13. You may not vote on this poll
  • I'd like the ability to manage backup data
    11 84.62%
  • I'd like Autodesk to introduce an option to overwrite backup data on a scheduled basis
    2 15.38%
  • I'm happy with the current backup solution
    0 0%
  • I don't have an issue with backup's consumming a large amount of space
    0 0%
Thread: Better control of the huge volume of backup files
    Active Member Chunk's Avatar
    2004-01
    Alberta, Canada
    63
    Default Better control of the huge volume of backup files
    Wouldn't it be grand if there was better control built-in to Revit to manage the overwhelming quantity of backup folders/files? I'm not speaking on single user files with redundant copies appended with 0001, 0002 etc. which we know can be controlled by specifying the number of backups under Save Options, but multi-user workset collaborations (recurrent theme with my posts isn't it!). Seems there are is inordinate amount of data space consummed by backups, each a single instance in a single cryptically labelled folder.
    Currently both local files and central files of projects are saved to our server. It was suggested that as an interim work-around we keep local files on local drives and only central files on the server. Still doesn't address the space consumption since we'll just redistribute it across 26 workstations instead of 1 massive server.....
    Member andremiko's Avatar
    2004-05
    Edmonton
    42
    Thumbs down Re: Better control of the huge volume of backup files
    You should try talking to Autodesk, apparently those folders are a "black box" and you don't need to know what's in them or what you can do with them.
  1. Dwf files end up being HUGE!!
    By MarkLyon in forum DWF Viewer - General
    Last Post: 2013-03-29, 12:52 PM
  2. Backup files should go into a "Backup" folder
    Last Post: 2012-03-09, 06:06 PM
  3. Control Folder Bloat - Simple deletion of Backup Files
    By iankids in forum Revit Architecture - Tips & Tricks
    Last Post: 2010-07-20, 02:44 PM
  4. Huge .dwg files, yet everything is purged
    By jdcincy in forum AutoCAD General
    Last Post: 2006-03-20, 06:28 PM
  5. Huge Plot Files!!!
    By martyk in forum AutoCAD Plotting
    Last Post: 2005-04-05, 01:02 PM
