I've just created a set of dynamic title blocks for the company I'm currently working for and a couple of its clients.
I set them up with different vis states for each size (A0 - A3) with one set of common attributes. I assigned a point parameter and a move action to each one coupled to a lookup list with co-ordinates for the locations on each sheet.
I did it, tested it and it worked fine, the only thing that needed doing was re-ordering the attributes as displayed in the edit box. I ran BATTMAN, shuffled the attributes around, saved the blocks and went to lunch. I Wblocked them out and overwrote the old ones, so no back ups (that'll teach me).
When I came back, I went to show it to another cad guy and the attributes went all over the place when I switched vis states. Thinking it might have been something not set right on his machine, I tried it on mine and the same thing - the default vis state (A0) displays fine, but when you switch to any of the others, the attributes just get shuffled all over the shop.
I really don't want to have to write out the list of co-ordinates for each one and start again. Is there any way to fix this? I'm using ACAD 2008 SP1 on XP.
