Thread: Printing Isometric wiew with hidden objects?
    2004-06
    94
    Default Printing Isometric wiew with hidden objects?
    The isometric view gives the opportunity to hide objects (by using the sunglasses)
    But when I print the view the objects appears anyway.
    Using the visibility-option doesn´t give the same result as I then have to hide all the objects of a certain type.
    I would be thankful for any ideas what to do
    I could stop if I wanted to Rhythmick's Avatar
    2004-03
    Colorado
    323
    Default Re: Printing Isometric wiew with hidden objects?
    There are two methods I'm aware of.
    Phasing - filter the view with phasing if it's applicable to what your trying to view.
    Worksets - filter the view by assigning all the elements your needing to their own workset or worksets and using the 'visibility' parameter to select the worksets you want in your view. A little caution in using worksets, it will add quite a bit to the learning curve, however it does open some doorways for using layers.
    My foundation iso attachment was done through worksets, but I would imagine it could have easily been accomplished through phasing, without involving worksets.
    Mike Lenz
    Genuine Homes Corp
    "Gone Fishing"
    2004-06
    94
    Thanks a lot !
    Anyway there must be a good (technical ?) reason for why the easy way of hiding objects by using the "glasses" isn´t printable. Otherwise always (?) "what you see on the screen is what you get" !
  1. printing hidden
    By Sideways Phoenix in forum Display Management
    Last Post: 2009-10-02, 05:09 PM
  2. Printing an Isometric 3D View to scale
    By bskripac in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-11-17, 09:35 AM
  3. Hidden object printing.
    By jmctamney in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-11-11, 10:14 PM
  4. Printing hidden lines
    By CadVizion in forum Revit Architecture - General
    Last Post: 2006-09-13, 04:06 PM
