Thread: Projection Section Label
    2009-12
    3
    Question Projection Section Label
    Maybe someone can help out here. I already posted this to the AutoLISP forum.
    I have projected cogo points to cross sections, and I need to show more information in the label than the style allows. However, if I reference every label to it's cooresponding cogo point, through properties. I will be able to us all of the properties of the cogo point in my label. (It seems like C3D should already do this, but it doesn't). Could someone help me in writing a routine that does this for all of my labels.
    I am thinking this is a simple as selecting all "AECC_SECTION_PROJECTION_LABEL" and setting the -Reference Text Object- to be equal to the -Projection Source Name- minus the word CogoPoint. The -Projection Source Name- appears as "CogoPoint 123". So the -Reference Text Object- need to be "123" and all the referenced labels will now reference the correct source.
    I have uploaded a jpg that may expain things further.
    Hopefully someone can help either with writing this or assisting me in writing this,
    Thanks in advance,
    Eric
    2006-10
    79
    Default Re: Projection Section Label
    i have the same problem did you find anything helpful?
  1. User defined Properties in Projection Label
    By valejandro_ibarra in forum AutoCAD Civil 3D - Profiles
    Last Post: 2011-01-12, 09:41 PM
  2. Section Projection Labels
    By mhooker in forum AutoCAD Civil 3D - General
    Last Post: 2010-06-16, 02:50 AM
  3. Projection Section Labels - Missing
    By emunchel in forum AutoCAD Civil 3D - Sections
    Last Post: 2010-06-14, 04:17 PM
  4. Civil 3D 2010 Section Projection Labels
    By enelson.237620 in forum VBA/COM Interop
    Last Post: 2010-01-03, 02:12 PM
  5. Section label problem
    By cadkiller in forum Revit Architecture - General
    Last Post: 2005-02-13, 11:41 PM
