Thread: ConvertPoly doesn't work?
    Cairo - no, not Illinois
    2,715
    Default ConvertPoly doesn't work?
    Hopefully someone will have a clue about this...
    I've got some drawings coming into 2009 from LandDesktop 2006 that contain old style Polylines. Osnap does not wor on them (NEA, INT, END etc.) - as presumably they were created by an old Softdesk command that was never updated for the "new" post R-14 LWPolys.
    The convertPoly command will theoretically convert the older style Heavy Polylines to the current Lightweight Polys -- but the only response I get from that tools is "0 Polylines converted"
    For that matter, PLINETYPE is set to 2, so any older heavy plines are supposed to be automatically converted, but that's not happening either.
    Any thoughts on cures or workarounds?
    Officially Awesome
    100 Club murrayc.49304's Avatar
    2003-03
    158
    Default Re: ConvertPoly doesn't work?
    Have you tried using the command CONVERT?
    2,715
    Yes, I've tried both CONVERT and CONVERTPOLY -- neither changes these polylines from old-style to lightweight.
    Some more digging into Help tells me that they can't be converted because there is XDATA associated with the vertices. Running XDLIST from Express shows that to be the case, SDSK and SV application data is attached.. That also explains why the PLINETYPE setvar is not impacting these objects.... It still doesn't explain why OSNAP can't find anything, so that is evidently a bug in 2009.
    Workaround A is to explode the heavy polylines, and the Pedit and Join them back into LWPlines.
    Ta Dah
    Officially Awesome
    2004-08
    Hartford, Michigan
    3,086
    Ta Dah
    not snapping to heavy polylines was a bug in 2009, it was supposedly fixed via one of the updates. You dont have to explode them, if they are continuous, just disable linetype generation.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
  1. DYN doesn't work
    By geohutto520336 in forum AutoCAD LT - General
    Last Post: 2012-02-04, 07:28 PM
  2. YES or NO to all doesn't work???
    By csmac2004 in forum Productstream - General
    Last Post: 2009-03-03, 05:31 PM
  3. Specify New Work Plane - doesn't work?
    By bnelson.188587 in forum Revit Architecture - General
    Last Post: 2008-07-24, 04:50 PM
  4. Pulish doesn't work
    By cwade in forum AMEP General
    Last Post: 2006-08-19, 02:57 PM
  5. When a repair doesn't work
    By rkmcswain in forum AutoCAD Tips & Tricks
    Last Post: 2006-08-09, 05:10 PM
