Thread: Local File Incompatible with Central File - Revit 2010 Error??
    2006-03
    34
    Default Local File Incompatible with Central File - Revit 2010 Error??
    Hello all,
    I've been using Revit 2010 for months now on Windows Vista with no problems. However, we recently updated to Windows 7, and ever since I receive the following error message when I try to save my local file (see attached for actual error message):
    "The file you are attempting to synchornize with the central file is not compatible with the central file. This could be due to an upgrade to a newer version of Revit or because the central file was substituted with an unrelated file using the same name. You must create a new local file and copy/paste any changes made to your original local file into the new file"
    I've already created a new local file from my Revit 2010 central file, and the problem persists.
    Any ideas?
    2006-03
    34
    Default Re: Local File Incompatible with Central File - Revit 2010 Error??
    Another update as I continue to try and debug the problem.
    I just tried create a new central file by "Save as - Create New Central File" and got the error message of "File not saved".
    That's it. No other information other than it won't let me save a central file either. I checked and it is recognizing my license, so there isn't an issue there.
    Any other ideas that could help would be greatly appreciated. Thanks,
    2006-03
    34
    Solved my problem. It was a network error on our end. Nothing wrong with the program or installation.
    False alarm. Thanks anyway to anyone who may have spent time checking it out.
    2006-04
    7
    Hey I have the same issue could you tell me what the problem with the network is?
    2006-03
    34
    We are using the Novell Network Client, and I believe that the new version was incompatible with Revit 2010's network licensing. So my IT staff I believe had to downgrade the version to get it to recognize the license server.
    That's as far as my understanding goes. Hope this helps.
  1. 2012: Local file synch to Central file on temporary server
    By amradcliff in forum Revit Architecture - General
    Last Post: 2012-03-29, 11:22 AM
  2. Revit 2011 Central File - Local Copy Issues
    By chris.klinert in forum Revit Architecture - General
    Last Post: 2010-07-08, 11:14 PM
  3. Recover backup of Revit Central or Local File
    By pbyrne in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-10-21, 04:39 AM
  4. Recover backup of Revit Central or Local File
    By pbyrne in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-10-21, 03:26 AM
  5. Recreating Local File from Central - requires new file name?
    By Haden in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2005-09-23, 06:15 AM
