Thread: Sheet set file won't delete
    2008-05
    Washington DC Metro Area
    15
    Default Sheet set file won't delete
    I moved the sheet set to a new folder but the sheet set file moved but cannot be erased from the original location on the server, no one is accessing it so I can delete it but it reappears after a second, I can't rename it because it reappears again as a new sheet set.
    Has this happened to anyone else? Anyone know a fix?
    2001-05
    Austin, TX USA
    2,201
    Default Re: Sheet set file won't delete
    Have you made sure that everyone that has accessed it completely shutdown AutoCAD? AutoCAD seems to hold onto the file even if the sheetset has been closed.
    2008-05
    15
    Quote Originally Posted by Glenndp View Post
    That was the deal, boss man was holding onto the file, he shut his CAD off and now it's gone, thanks. I tried to check his machine before but he was behind closed doors.
  1. 2014: delete empty View/sheet set
    By mostafa90 in forum Revit - API
    Last Post: 2014-08-06, 06:25 PM
  2. Cnnot Delete Sheet from Sheet List
    By laryssa in forum Revit Architecture - General
    Last Post: 2010-09-03, 10:20 AM
  3. Can't delete APJ file
    By dzatto in forum Project Navigator
    Last Post: 2009-06-05, 09:15 PM
  4. How To Delete A Sheet Set
    By Spanky in forum AutoCAD Sheet Set Manager
    Last Post: 2008-06-04, 04:03 PM
  5. Can't delete a file?
    By patricks in forum Revit - Platform
    Last Post: 2008-03-31, 01:31 PM
