Results 1 to 1 of 1
Thread: Slow Startup in 2010
    I could stop if I wanted to tonyisenhoff's Avatar
    Milwaukee, Wisconsin
    424
    Default Slow Startup in 2010
    Revit 2010 w SP2
    We have a handfull of PC's that randomly have slow startups. Instead 1-2 minutes, we're talking 6-10 minutes (if the user waits that long...). The impatient users typically end the process, then re-launch the app with better luck, but not all the time.
    After reviewing the jounal files from when the issue occured, I've narrowed it down to one of two sections.
    1. InitInstance (see screenshot below)
    This is only one line item and it alone took ~ 5 minutes in this example.
    2. Loading available hardware/plotters (see screenshot below)
    This can also take some time to complete, but not every time. I've clipped out most of this section because it's pretty long. I left the beginning and the end. This one took ~ 6 minutes to get thru just this section of the journal.
    Like I said, it's only a handfull of users that experience this and it's not all the time.
    Any thoughts on what could be causing either of these slow-downs?
  1. Slow startup
    By Jmc3198 in forum AutoCAD Civil 3D - General
    Last Post: 2009-08-14, 05:02 PM
  2. Revit 2010 crash on startup
    By osama.215867 in forum Revit Architecture - General
    Last Post: 2009-07-06, 05:15 AM
  3. AutoCAD 2007 is slow to Startup
    By wayne.peterson in forum AutoCAD General
    Last Post: 2009-06-12, 05:28 PM
  4. Startup time for Design Review seems very slow
    By bart.blankendaal in forum Design Review - General
    Last Post: 2009-06-04, 07:54 PM
  5. AcadMap3D 2005 Slow startup
    By stewart.bragg in forum AutoCAD Map 3D - General
    Last Post: 2005-06-01, 07:04 AM
