Thread: problem with labeling contours in C3D 2010
    2009-12
    42
    Question problem with labeling contours in C3D 2010
    I'm having a strange problem with labeling contours in C3D 2010. I have my label style set how I want it. I go to add my lables (using the single contour label command), and sometimes a proper contour elevation label is added, but other times it just adds a tick mark (similar to something you would see on an alignment. I have tried tweaking every style setting I know of. Does anybody have any ideas or thoughts?
    Thanks.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Default Re: problem with labeling contours in C3D 2010
    Can you post a sample showing the problem?
    All AUGI, all the time brian.hailey933139's Avatar
    2006-12
    Loveland, CO
    734
    My guess, you created your surface from contours that are, for example, 1' contours. The surface you created are displaying 2' contours. The ticks that show up are not on a contour, they are on a polyline that you used to create the surface. Change the surface style to a tighter interval and hopefully your labels will magically appear.
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
  1. Replies: 2
    Last Post: 2010-06-29, 08:26 PM
  2. Surface Labels - Labeling Contours
    By martyk in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-08-12, 07:35 PM
  3. Revit 2010: BUG - Export to NWM 2010. World units problem
    By sinzoff in forum Русский - Revit
    Last Post: 2009-05-22, 10:26 AM
  4. i'm labeling some contours and.....
    By ntnik in forum Revit Architecture - General
    Last Post: 2009-02-13, 11:45 AM
  5. Labeling Contours
    By gisdude in forum Land Desktop - General
    Last Post: 2005-10-05, 08:31 PM
