My goal is to publish drawings using the DWG to PDF plotter. I would like to turn off the option "Open in PDF viewer when done" located under the plotter custom properties. When I try to save the setting "uncheck" it always automatically revert back to be checked..? The problem is that if you have the PUBLISHCOLLATE set to 0 you're going to have a billion iteration of PDF viewer opening all over your desktop... Any one has a good recipe?
