I have to show door grille on my drawing , How do I go about creating a door grille. I can not found it in the family list.
thanks
thanks
I would use the OOTB sidewall return hosted on the door.
We used a side wall grille as well.
We placed parameter to change the grille size and the height from FFL. So when the Door Grille is 400x200, and need to be 400x600 high, it's done through the family parameter preset and in the propeties box.
We also added symbolic square on top with stronger line type to show up.
Also a shared parameter was added for the tag. If the Triangle tag's number is changed to 1,2 or 3, the grille height changes respectively.
We didn't bother with having actualy blades on the grille since it's too much work and lags the model.
Q: What is a beancurd?
The angry revit monster!!...Raaaaar!!
Hi,
Have You tried this site?
http://smartbim.reedconstructiondata...bjects%7CDoors
Regards
Andre
