Thread: What can I do to mess up the model?
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,560
    Default What can I do to mess up the model?
    I'm putting together a Lunch & Learn session titled "What can I do to mess up the model?" & I thought it might be a fun discussion on AUGI as well. Here's the list I've got so far:
    Lots of big ugly AutoCAD drawings
    That’s not “just a line” - Deleting floors
    Explode AutoCAD drawing
    Change Family size but not name
    Import DWG instead of Link
    Over-detailing
    Putting things on the wrong workset
    Locking Walls
    Change a Family Type instead of creating a new one
    Deleting elements instead of modifying an existing one
    Locking a dimension, then deleting it.
    Not just deleting floors, but anything they don't verify what it is or talk to the team.
    Ignoring lower right warnings without understanding them or going back to clear them.
    Not using groups or changing a group when you should make a new one or ungroup that one.
    Not using design options for a PR issue.
    Not talking to your team so you know what each other are doing.
    Not considering early what custom families would help and requesting them.
    Drafting too much.
    Too many In-place Families
    Placing multiple family’s on top of one another, because it did not show up in your current view (visibility graphics).
    Using Text instead of Tags
    Remove a Link instead of Unloading (after VV was set up)
    Last edited by DaveP; 2010-01-13 at 09:30 PM. Reason: That's what I get for pasting from Word
    Go back to AutoCAD? I'd rather lose my right arm!
    100 Club smcmillin's Avatar
    2006-07
    180
    Default Re: What can I do to mess up the model?
    Nice list, I wish I had something to add, but I can probably fill an hour on "Change a Family Type instead of creating a new one" alone.
    A lunch & learn on best practices when working with an MEP consultant using Revit would also be a good one.
    You can't triple stamp a double stamp Lloyd!!!
    I could stop if I wanted to TroyGates's Avatar
    2015-08
    Irvine, CA
    281
    * Deleting a level line in an elevation or section instead of hiding it.
    I usually demonstrate this in my training classes to show the impact that levels have on all objects since all objects require a base level. To sum it up, it deletes all the objects that have a base set to that level.
    I could stop if I wanted to Phil Read's Avatar
    2003-05
    Charlotte, NC
    398
    Quote Originally Posted by DaveP View Post
    Hi Dave -
    I wouldn't even remove it. I'd associate it to a unique workset (ie, "Link - Structure") and then close the Workset.
    This allows one person to close the Workset in their unique Local file without Unloading it (which effects the whole project and team).
    I've seen Unloaded links get Removed and re-linked when someone is in a hurry - and all of the dimensions, etc associated to that link get deleted. Closing an associated Workset avoids this. Just remember to Open all the Worksets when printing!
    BTW - still remember #3 on your list well.
    -Phil
    Pittsburgh, PA USA
    1,906
    After setting up Copy/Monitor with a consultant, Deleting something that they are monitoring, without telling them that it was done in an email. This causes an entry in the Monitor report that will never go away.
  1. 2011: hatching around blocks leaves a mess
    By Darren Allen in forum AutoCAD LT - General
    Last Post: 2015-07-30, 11:27 AM
  2. Error mess
    By genesisd_d in forum AutoCAD General
    Last Post: 2007-11-16, 11:45 PM
  3. Did I mess up project north?
    By petervanko in forum Revit Architecture - General
    Last Post: 2006-10-11, 09:28 PM
  4. 2nd floor mess- wall visibility
    By Maximillian in forum Revit Architecture - General
    Last Post: 2006-10-11, 07:35 AM
  5. Grid line mess
    By Allen Lacy in forum Revit Architecture - General
    Last Post: 2003-07-03, 10:39 PM
