Thread: Crane rail style
    2003-12
    Saginaw, MI
    4
    Default Crane rail style
    I'm trying to create a craane rail that works like a beam. I've created a shape and style, but when I apply to the beam it does not show up as a crane rail.
    2002-09
    Madison, WI
    5,411
    Default Re: Crane rail style
    Why not just use the OOTB crane rail? "S" shapes are available as a structural member.
    If you want to use your own profile, create the profile shape and create a new structural member style and use your profile.
    I took a look at your style, all you needed to do was change the profile to your "rail" profile in the member style.
    Let us know if you have additional questions.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2003-12
    Saginaw, MI
    4
    Quote Originally Posted by david_peterson View Post
    Not sure what an OOTB is? I never thought to check the "S" shapes for a rail, I know "S" shapes are used for trolly's, but this needs to be a rail.
    As for applying the "rail" profile to the member style, I did, but no change. I figured it must not be that easy!
  1. Replies: 0
    Last Post: 2011-11-17, 10:55 PM
  2. Crane
    By stusic in forum DV - Gallery
    Last Post: 2009-08-01, 02:26 AM
  3. Crane Rail Beam Family
    By dlampley.41310 in forum Revit Structure - Families
    Last Post: 2009-07-02, 09:03 PM
  4. Crane Rail needed!
    By dan.ungureanu in forum Revit Structure - General
    Last Post: 2008-01-23, 08:19 PM
