Thread: modify file associations
    0,0,0 The Origin
    8,024
    Default modify file associations
    In an explorer window > Tools > Folder Options > File Types > highlight DWG in list, > Advanced > highlight OPEN > Edit... > (If open isn't there use New.. to create it.)
    check that - Application used to perform action: = "C:\Program Files\AutoCADversion\acad.exe" "%1".
    check that - "Use DDE" is checked.
    check that - "DDE Message:" = [open("%1")]
    I can't see an equivalent in Win_7 - has anyone else found it?
    This is the closest I have found -
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2001-05
    Austin, TX USA
    2,201
    Default Re: modify file associations
    In Windows Vista and 7, right-click on a file that is the type you want to associate to a program. In the dialog box either select the program or use the "Browse" button to locate the program. Make sure that "Always use the selected program to open this kind of file" is checked.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    0,0,0 The Origin
    8,024
    Thanks Glenn - that's exactly the same functionally (via a different route) and gives no ability to control DDE or to add functions like "plot".
    John B
    2001-05
    Austin, TX USA
    2,201
    If you need those other features the following might be of help. Its a blog post describing different programs that allow you to change those settings.
    http://www.mydigitallife.info/2008/0...agement-tools/
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    0,0,0 The Origin
    8,024
    That's the right gear.
    John B
    0,0,0 The Origin
    8,024
    Slightly connected -
    In Windows 7 explorer, on the menu bar, the second button is "Open" and it has a drop-down list so you can pick any installed programme (like different acad.exe versions).
    John B
  1. Forcing File Associations
    By sclod13 in forum CAD Management - General
    Last Post: 2010-09-21, 07:02 AM
  2. Modify a non-standard linetype file
    By vancesinger in forum AutoCAD Customization
    Last Post: 2009-02-11, 05:56 PM
  3. Cannot modify the library file...
    By mschara in forum Inventor - General
    Last Post: 2007-05-14, 08:37 PM
  4. Level/Plan associations
    By david.delcher in forum Revit Architecture - General
    Last Post: 2006-09-12, 05:26 PM
  5. Unable to modify file C:\...\...Piston.iam!
    By Cosmic Traveller in forum Inventor - General
    Last Post: 2005-12-22, 04:55 PM
