Results 1 to 9 of 9
Thread: transparent massing casting shadows?
    100 Club sami's Avatar
    2008-09
    Toronto, Canada
    149
    Default transparent massing casting shadows?
    If I mass a building and have its material transparent, then it doesn’t cast shadows, is there a way to have it cast shadows and still be transparent?
    Sami Kazemi
    Architect, OAA, LEED AP
    Toronto, Canada
    www.kazemi.ca
    Revit Architecture 2011, Windows XP
    2005-07
    Somewhere in the BIM world
    3,147
    Default Re: transparent massing casting shadows?
    Why would a transparent material cast shadows?
    2008-09
    Toronto, Canada
    149
    in the case of creating a schematic massing of a building, the transparency of the building would only be a graphic representation so that we can better see its relation to its context.
    PS in reality glass does cast a shadow, its just translucent based on the opacity of the glass.
    Sami Kazemi
    Toronto, Canada
    www.kazemi.ca
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Quote Originally Posted by sami View Post
    Yes, change the material properties of the glass that the mass uses to be something other than 100% transparent.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2008-09
    Toronto, Canada
    149
    Quote Originally Posted by Scott Davis View Post
    when I change the material transparency to any number other than 0% I lose the shadows in shaded views. (This is the transparency slider bar under Materials/Grapics/Shading)
    am I missing something here?
    Sami Kazemi
    Toronto, Canada
    www.kazemi.ca
    2005-07
    3,147
    No you got ti right. As soon as you change the transparence y value to other then 0% it won't cast shadows.
    2003-04
    Chino, CA
    4,743
    Quote Originally Posted by dhurtubise View Post
    Hmm interesting. I thought that I have changed the settings before where some transparency would cast shadow...sorry about that!
    Scott D Davis
    Autodesk, Inc.
    2003-08
    Vancouver, BC Canada
    3,419
    I recall that too Scott. I think prior to 2008 there was a 'point of no return' (about 65% if I recall) where transparent masses would still cast shadows. Probably one of the things that was 'fixed' at someone's request
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2005-07
    3,147
    Quote Originally Posted by Dimitri Harvalias View Post
    ahahah One of those fix
  1. Linked file not casting shadows
    By jameswest77 in forum Revit Architecture - General
    Last Post: 2011-12-01, 08:17 PM
  2. Detail components casting shadows
    By jetisart in forum Revit Architecture - General
    Last Post: 2010-09-22, 11:37 PM
  3. Light Fixture Modeling... Casting Shadows on Itself
    By saeborne in forum Revit Architecture - General
    Last Post: 2009-10-14, 09:44 AM
  4. Filled region casting shadows
    By eddy.lermytte in forum Revit Architecture - General
    Last Post: 2005-09-09, 08:09 AM
  5. Shadows casting on background image when printing.
    By Silkie in forum Revit Architecture - General
    Last Post: 2005-02-17, 10:14 AM
