Results 1 to 10 of 13
Thread: Making those pesky constraints behave
    2009-07
    5
    Default Making those pesky constraints behave
    MAJOR UPDATE
    I have edited this post from its original form to update a major discovery I have made.
    The constraint system in Revit isn't the best, nowhere on par with Solid Works, and it was constantly driving me nuts telling me that my constraint system was invalid when it clearly was not.
    So I set out to figure out how to tame this problem, and this is what I have found so far:
    Rules to make parameterized constraints "behave":
    1. Always attach parameterized constraints to planes. Just do it. Things are complicated enough without doing so.
    2. You cannot LOCK a dimension between two planes if those two planes already have dimensions relative to each other, even if those dimensions are ALL unlocked and even if they exist in other views.
    (Exception: if those dimensions are of the 'equal spacing' type, and equal spacing has ALREADY been enabled.) Error: "Locking this dimension would overconstrain the sketch." You should therefore avoid unnecessary dimensions.
    3.When a dimension is assigned a parameter, or when an assigned parameter changes value, Revit always tries to move the "preferred plane" of that dimension, UNLESS that plane is DIRECTLY PINNED. What "preferred plane" means I'll explain presently.
    If you dimension two objects, then assign a parameter, revit will always move the preferred plane, unless you PIN it, in which case the other plane will move, as expected.
    If, however, you lock the preferred plane to another object that is pinned, Revit is unable to detect that the preferred plane has been pinned by proxy and gives a "Constraints not satisfied" error, even though it could move the other plane to solve the constraints. You have to be careful with the "pinned by proxy" concept, because you may need to go back quite far in your constraint system to find out that a certain plane is actually pinned in place.
    Be VERY careful about adding pins, because it is easy to break your design simply by adding a pin. Try to decide on one and only one plane to pin in each axis, pin it early, and stick to it. If you do have to add or move a pin, carefully check each and every parameterized constraint to be sure it behaves as you expect.
    A good example of when this crops up is when you want to have two planes equidistant around a pinned center plane. (This is exactly what you very often do first, before doing anything else.) If you have the two movable planes drawn around the center pinned plane, then dimension them equally, then draw a dimension from the center plane to one of the outer planes and attempt to assign a parameter to that, the assignment will fail if the preferred plane of that dimension is the center plane. The solution, or course, is just to change things so that the preferred plane an outer plane (which may be complicated to do). Now it is the outer plane that moves when the dimension changes, and the entire system behaves as expected.
    So how do you know which plane is the "preferred plane"? Many times I thought I had this figured out and each time I was proven wrong. The best way to test is simply to create two planes, set a parameter, and see which leg moves. Here are some things you can try:
    a) In many views only either the left or right (top or bottom) leg will move, no matter what you do. If this is the case you have to dog leg. (See below.) This was originally the way I thought all views worked, but... nope! It's true about 90% of the time.
    b) Try connecting the planes in reverse order. (That is, click the right plane first when creating the dimension instead of the left leg first.) Sometimes works. Usually not.
    c) Try erasing one of the two planes (if you haven't already drawn dimensions to it -- otherwise you're just making more work for yourself), recreate it, but this time draw it from bottom to top instead of top to bottom. (Again, rarely works, but sometimes does.) You can try this in combination with #2.
    d) Switch to the opposing view. Normally you should draw all dimensions in one view, but sometimes you get the other leg to work by switching views -- left to right, front to back, etc.
    e) Draw a pentagram on the floor, don a black hat, and perform some black magic.
    If you can't get the leg you want to move, you can create a "dog leg."
    By a "dog leg" I mean creating a loop-back and adding an extra dimensioning plane. In our example, we want the right leg to move, not the left leg, so we create an extra leg to which we attach a new parameter, and attach that plane to the original plane at some fixed distance (larger than our parameter will ever become.) In this case, our parameter is 1'2" ... I'll pretend the parameter will never get larger than 2' and put a use 2' as my offset. Create a new parameter (legnth2 in this case), and give it the formula length2=offset-length. In this case, length2 = 2' - length. Then lock the dimension between the new plane and the plane you want to move to 2 feet. Now when you assign the parameter "length2" to the dimension, the left leg of that dimension moves, but it is attached permanently to the right most plane we originally wanted to move. Presto, problem solved.
    Finally, when you do your flex testing, it is better to flex each individual parameterized constraint by changing WHICH parameter variable controls that constraint and then changing it back. (Be sure you change it to a variable with a different but reasonable value.) Why? Flexing the design using the types box can actually hide some more obscure problems that you can otherwise catch.
    4. Constraints cannot be assigned parameters that have negative values. These will always fail because Revit will reverse the direction of the leg, measure it, find it to be positive (going the other way), and complain because that distance is not negative.
    The solution to that is to use a round-about extra plane as shown above. Simply dimension a plane far out in the negative direction, then create a new variable "newvar=offset-oldvar", and assign that to the distance between the extra plane and whatever it was you wanted to move. So long as the offset is larger than the magnitude of the most negative value oldvar will ever attain, you are OK. Notice that the factory does this in many of their framing families: the extensions on framing members can be negative, and they use a 10' offset. If you try to assign an extension more negative than 10', those factory families will fail.
    5. If you want to align an extrusion to something else in your family, you usually cannot do so if that extrusion contains constraints or has curved sides. The reason is that revit tries to resize the extrusion instead of simply moving it, and it never seems to correctly resolve the restraints internal to the extrusion. Curved sides will not snap to anything anyway.
    The solution to this is to place the extrusion in a group and place a few reference planes in the group editor mode along with the extrusion. When you draw the extrusion, draw ANOTHER SET of reference planes in that mode too. When you are done, align the reference planes in the extrusion path mode to the reference planes in the group, BUT DO NOT LOCK THEM. If you lock them, Revit will complain. You do not need to lock them in place anyway, because the entire system resides in a group that will move as a whole.
    Now when you exit the group, you can align the entire group using the reference planes in the group, as they will be visible outside the group editor. (The reference planes in the extrusion are not visible from outside the group editor.)
    6. Do not directly parameterize model lines in extrusions. This probably applies to groups as well, but I haven't tested it. Instead, parameterize planes and lock model lines to the planes. If you don't do this the worst possible nightmare may befall you: the parameter may appear to work in the family editor, but when you attempt to load the family for actual use, loading types may fail! This has happened to me and it was very frustrating to diagnose.
    7. When creating arrays, place the objects to be arrayed into a group first, add some reference planes, and then align using the references planes to the project. If you do not do this you may also have a family that works in the family editor but not in the project.
    With this information I have had MUCH more success building families. I hope it helps you too. Maybe the factory will work on the constraint engine and make it a little more robust. (Maybe they can steal that part from Inventor?)
    Last edited by confirm2; 2010-03-05 at 04:17 AM. Reason: Found how "up" is determined
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Default Re: Making those pesky constraints behave
    Well researched!
    Do you have any insights into what causes mystery constraints to happen or not? I use superstition, try flexing, and if things need to be fixed I start putting dimensions all over the place. Sometimes even when things are symmetrical, mystery constraints do not seem to behave consistently on the left and the right. I'm simply used to it.
    2009-01
    111
    You should work/moonlight for Autodesk - they could use some additional documentation.
    I found this really really helpful.
    2009-07
    5
    Quote Originally Posted by truevis View Post
    I'm sorry, I don't know to what you are referring. I have found that sometimes Revit can get become internally inconsistent and not behave correctly at all, in which case the only thing to be done is to start the design again. However, in general, using these rules I have not had any problems getting anything done.
    2004-07
    Massachusetts, USA
    1,191
    Quote Originally Posted by confirm2 View Post
    I'm sorry, I don't know to what you are referring...
    By mystery constraints, I mean the phenomenon of sketch lines sticking near reference planes and sometimes not.
    2010-01
    Southeast Asia
    3
    Interesting work.
    I used to have an awful lot of trouble on this front as well. One of the ways i found to get around it was to set up parameter driven 2D profiles that i would nest into a host family.
    This video kind of gets to the point:
    the smaller bits i gave revit, the better behaved it became. I also had to get kind of creative with how i fed it parameters...but it can be done!
    2001-12
    Irvine, CA
    7,369
    A few comments that may contribute to the whole thread?
    Automatic Sketch Dimensions - Most users seem to miss that these exist. Visibility Graphics > Annotation Tab > Check Automatic Sketch Dimensions. When you add a parameter to a dimension Revit starts creating ASD's to deal with the stuff you create that is not explicitly constrained. Revit constrains orthogonally X/Y so angles are tricky because behind the scenes ASD's are really interested in the X/Y dimensions to the ends of an angle line. ASD's are really Revit "guessing" what you want. A simple family Revit guesses well. A complex family not always so the more complex the more likely a ASD will "getcha". To see ASD's just create a couple of reference planes and add a parameter to a dimension between them. Then create a solid extrusion...as soon as you start sketching a line in sketch mode ASD's will appear (assuming you turned on the category in Visibility/Graphics).
    A family has an origin just like a project, import a dwg with a cross hair at 0,0,0 using Auto-Origin to Origin to verify that the stock reference planes are actually at the origin. I've seen room/space tag families that have been built far away from origin and end up outside their room when you try to use them.
    Once you add a parameter, don't try to change things on screen (in canvas) use the Types dialog to enter new values. Autodesk is gradually changing this rule and you can see that in the new massing editor. Dimensioning in a family is NOT a drafting exercise or drawing convention, it is defining rules.
    A Reference Plane has a "head and a tail". The head is where the Name parameter appears when you assign one. The positive direction of solids created assigned to a Reference Plane is determined by where the head is. The positive direction is "up" to the "left side of the Head. Sketch a pair of reference planes, one left to right and the other right to left and name them, using a Strong Reference setting for the IsReference parameter. Create two solids one assigned to each Reference Plane...you'll see they extrude in opposite directions. One quirk, for some reason the stock reference planes you find in a template behave in the opposite direction with respect to the head and tail, go figure. Fwiw, I've been writing about this stuff on my BLOG for what seems like ages now.
    Most dimensions don't really need to be "locked" because the act of adding the dimension is effectively constraining the relationship already.
    2001-12
    1,714
    Another worth mentioning.
    In general it is best to define "interior" relationships prior to "overall" relationships. You see this pattern in setting the EQ pair before you set the overall dimension.
    However, sometimes you find something that already has the overall in the template. For example, I recently needed a relight with top and bottom frames but no side frames. I started with a Door template and changed to Window (because I didn't want to deal with a sill height) and added Ref Planes for Top Frame and Bottom Frame. Dimension each and try to apply the Frame Width parameter to the top frame dimension results in Constraints not satisfied, because the "preferred" ref plane is the Top that came in the template, not the Top Frame we just created. You could play the dog leg game, or dimension both frames off the Reference Level. Or you can just delete the "Height" dimension. Now when you apply Frame Width the overall height will come down, without an Unsatisfied Constraints error. Then re-dimension the Height and the Top moves back where it belongs, taking the Top Frame with it.
    Gordon
    2007-03
    Salt Lake City
    360
    Quote Originally Posted by Steve_Stafford View Post
    Any way to get rid of this? I need to cut a series of voids out of a solid, where the solid can change shape, but the voids stay consistent. I'm using this in a curtain wall and want to adjust the panel size, while the void stays the same.
    2001-12
    Irvine, CA
    7,369
    Quote Originally Posted by t1.shep View Post
    The only way to eliminate ASD's is to provide the constraints Revit needs to understand what you really want. Add your own reference planes, dimensions/parameters/labels, align and lock etc until the ASD's are no longer present or constraining the component differently than you want.
  1. Making Revit Behave... Possible Wishlist Item?
    By ronsarlo in forum Revit Architecture - General
    Last Post: 2012-01-12, 07:08 PM
  2. 2011: pesky radius
    By fwaldropii in forum Revit Architecture - Families
    Last Post: 2011-07-08, 06:43 PM
  3. "Constraints are not satisfied" message when making grid lines equal
    By rachaelferrill in forum Revit Architecture - General
    Last Post: 2009-09-04, 09:13 AM
  4. Making Rope and driven constraints
    By stalljeffman in forum Inventor - General
    Last Post: 2006-10-11, 01:21 PM
  5. Help reassigning that pesky F1 key
    By BrenBren in forum AutoCAD FAQ (Read only)
    Last Post: 2006-08-31, 01:06 PM
