Results 1 to 8 of 8
Thread: date stamp
    2009-07
    103
    Question date stamp
    i have a text block that will add the directory of a drawing as well as the lat person wo worked on it and a date and time stamp, does anyon eknow how i can change the month to be all capital letters?
    Earth
    9,805
    Default Re: date stamp
    Explore the (strcase) function.
    If you are using any DIESEL, it has it's own function named "upper"
    R.K. McSwain | CAD Panacea |
    2009-07
    103
    Question Re: date stamp
    sorry we are not, when i do an edit it come up like an excel format.
    do not know if this helps.
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Could you maybe post a sample DWG?
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by mgonzales.224492 View Post
    are you using fields? if so, I believe you can adjust the formatting so that it will show the month in all caps. Fields and text would probably be much simpler than using programming to insert the information.
    2009-07
    103
    here is the block, i would like to get the month to be in all caps, and change the font to a block font.
    if you can help it would be great.
    2004-08
    Iron Station, NC
    3,198
    I got you, you are using RTEXT, I dont have much experience with that but I do know that is an old express tool, I would recommend switching it out for something more modern
    2015-11
    Jo'burg SA
    4,512
    Well, you can do exactly the same thing using Diesel in a normal Field. Simply list the RText and see what its expression is. Open the text screen (F2) and select and copy (Ctrl+C).
    Then edit / create a normal DText or MText and start a field (Right-click --> Insert Field or just Ctrl+F). Browse to the Other field category and select Diesel Expression as a Field name. Paste that code into the Diesel expression edit box. Then add the upper diesel function to convert to uppercase. The diesel code should look like this:
    $(upper,$(edtime, $(getvar, date), "MONTH YYYY"))
    The final field code looks like this:
    %<\AcDiesel $(upper,$(edtime, $(getvar, date), "MONTH YYYY"))>%
    And then of course you can see this in the attached, where I've placed this field inside a normal MText.
    BTW, seeing as you're using RText (which is not "really" available anymore) what version of ACad are you using? Using the Diesel expression as above in a new RText gives the same result - also in the attached.
  1. Customize Date stamp?
    By ben76red in forum Revit Architecture - General
    Last Post: 2010-06-16, 12:49 PM
  2. date stamp
    By chris.macko125036 in forum Revit Architecture - General
    Last Post: 2008-10-02, 03:50 PM
  3. Date Stamp
    By alana116 in forum CAD Management - General
    Last Post: 2008-07-15, 07:26 PM
  4. Date Stamp Routine
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2005-06-03, 12:31 PM
