Thread: Clash Detection Reporting
    Exclamation Clash Detection Reporting
    What is the best way to run a report?
    When I write the report to HTML and then print form the HTML, the printed document cuts off images. Yes I know it is best to review clashes right from the HTML file or even the NWD file in Freedom. However, if I want to create a hard copy, what is the best, cleanest, most presentable way of doing that.
    Thanks for your time
    2015-12
    2,048
    Default Re: Clash Detection Reporting
    I think the best for now is HTML (we just use it for yellow-off, so the cut-off doesn't matter much). As I am currently tinkering with XSLT and learning some basic HTML, I am considering a couple of "enhanced reporting" options based on the XML report format. Not sure if there is a "page break" equivalent in HTML, though - that would make it difficult.
    Edit: not directly, but CSS looks promising with page-break-before/after/inside properties...
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    2015-12
    2,048
    Yeah, I can do it with CSS by diddling with the <style> element, but only manually for now. And its not practical for anything approaching a realistic sized clash report.
  1. Clash Detection
    By brian.elbe in forum NavisWorks - General
    Last Post: 2010-09-28, 08:45 PM
  2. What is clash detection?
    By volker.joseph in forum NavisWorks - General
    Last Post: 2009-05-19, 02:36 PM
  3. Clash detection and distance
    By rrijswijk.104343 in forum NavisWorks - General
    Last Post: 2008-05-14, 03:51 PM
  4. ABS clash detection?
    By peter.rumpf in forum AMEP General
    Last Post: 2006-02-01, 02:37 PM
  5. clash detection?
    By peter.rumpf in forum Revit Architecture - General
    Last Post: 2006-01-18, 05:07 PM
