How can i match the ceiling grid to the rendering. The light fixtures placement don't show correctly.
You need to adjust the orientation of the ceiling material map in Accurender. Using the Maps tab, select ceiling material, edit then select orientation and adjust the x and y offsets.
You will probably need to run a few region raytraces first to get things looking just right, adjusting the orientation of the ceiling grid incrementally as you go.
