Thread: Matching ceiling grid to ceiling rendering
    100 Club Nevine's Avatar
    2003-05
    Cincinnati
    123
    Default Matching ceiling grid to ceiling rendering
    How can i match the ceiling grid to the rendering. The light fixtures placement don't show correctly.
    2003-05
    5,153
    Default Re: Matching ceiling grid to ceiling rendering
    You need to adjust the orientation of the ceiling material map in Accurender. Using the Maps tab, select ceiling material, edit then select orientation and adjust the x and y offsets.
    You will probably need to run a few region raytraces first to get things looking just right, adjusting the orientation of the ceiling grid incrementally as you go.
  1. Ceiling (Grid Only?)
    By cek in forum Revit Architecture - General
    Last Post: 2018-08-24, 07:50 AM
  2. 2014: Grid Ceiling
    By AhmedHamdy in forum Revit Architecture - General
    Last Post: 2014-06-27, 04:19 PM
  3. What do you do when there is no ceiling grid?
    By Mitch Mermel in forum Revit MEP - General
    Last Post: 2010-06-14, 04:04 PM
  4. ceiling grid
    By aaronwsmith in forum Revit Architecture - General
    Last Post: 2006-11-22, 09:06 PM
  5. Matching ceiling grid to ceiling rendering
    By Nevine in forum Revit Architecture - General
    Last Post: 2004-11-27, 06:55 AM
